Cam drivability without tune - Mustang Evolution
Old 03-17-2015, 09:41 PM   #1
keeney35's Avatar
So I got all my parts in my trunk lol finally gonna get the cams in this weekend.. I have the comp stage 3 cams.. The car no longer has a tune, so as far as this being my daily will I be hurting anything driving it with these cams and no tune? I will be getting a tune soon just gotta pay for the sctx4 and the tune so it may be a couple weeks..
keeney35 is offline   Reply With Quote
Old 03-17-2015, 10:21 PM   #2
joe_117's Avatar
What mods are you running? I kinda want cams but I heard it takes a lot of replacements for cams to be good to the engine
joe_117 is offline   Reply With Quote
Old 03-17-2015, 10:25 PM   #3
keeney35's Avatar
I've got a 73mm bbk throttle body/plenum, steeda cai, steeda underdrive pullies, full msd ignition, full exhaust but haven't got my headers on yet..
Old 03-17-2015, 10:59 PM   #4
Panther140's Avatar
Even if you don't degree them, you will be fine. Upgrade the valve springs. Stage 3 cams at high rpms with stock valve springs will cause valve float and possibly cracking the valve spring. Degreeing the cams will make you get the most out of them, a CUSTOM tune with a typical stage 3 cam will also help
Panther140 is offline   Reply With Quote
Old 03-17-2015, 11:35 PM   #5
keeney35's Avatar
Already have the new beehive comp springs and retainers
Old 03-17-2015, 11:37 PM   #6
keeney35's Avatar
By degreeing them im assuming you mean the timing? Mechanic is gonna re key the factory cam gears
Old 03-18-2015, 03:34 AM   #7
DetroitMuscle99's Avatar
Your car won't hold idle right until it's tuned. It will start and run fine but when you go to drive, it will want to stall out. I have the same cams but also did ported heads at the same time.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 03-18-2015, 07:53 AM   #8
keeney35's Avatar
Can I not adjust the throttle screw to help that stalling? Or just keep the clutch in and give it a little gas to keep her alive
Old 03-18-2015, 10:05 AM   #9
Panther140's Avatar
yeah you can do that to get by. Idk about throttle screw though. THe ECU might not like starting with the throttle cracked open on a cold day, but idk. I don't make the rules, I just circumnavigate them.
You see, if you had a carburetor it would take about 10 seconds to tune the idle for the cam and it would be completely free.. maybe that's why they don't have them anymore!! Why would they want that when they can charge you hundreds of dollars to adjust **** on an EFI car??
Old 03-18-2015, 10:22 AM   #10
keeney35's Avatar
Riight??? I miss the old cars when it was all simple that's what I learned on.. But hopefully we can get to hold an idle, if not i will get her tuned in the next few weeks
Old 03-18-2015, 10:34 AM   #11
Panther140's Avatar
Yeah I bet it will idle fine. Just might have an off-idle stumble that you gotta blip the throttle for. But that's only for people who don't go wfo to start off like I do.
Old 03-18-2015, 10:38 AM   #12
keeney35's Avatar
Yeah I don't go wo everytime but I do quite frequently lol I'm hoping this idle is loud and proud with my alresdy loud idle with no cats lol
Old 03-18-2015, 10:52 AM   #13
Slater2111's Avatar
Don't touch that throttle screw. It doesn't work like an old carb would. Messing with that is one of the biggest things that messes up a cars tune.
You're spending good money to put a big cam in the car. Along with the supporting mods. Go ahead and spend a little more money and get it tuned. Also if you're doing all this work go ahead and degree the cams. Might as well do it right and once and for all.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 03-18-2015, 11:14 AM   #14
Panther140's Avatar
Yeah with something like this, you're better off going all out the first time. Its harder to go back in and degree cams after the fact
Old 03-18-2015, 02:05 PM   #15
keeney35's Avatar
By degreeing the cams you mean what? I feel like I know but I wanna be sure
Old 03-18-2015, 02:08 PM   #16
Panther140's Avatar
Yeah in essence you are just deciding for yourself how to orient the cam
This video should get you started:
Old 03-18-2015, 02:23 PM   #17
keeney35's Avatar
When he referred to the cam sprocket I'm assuming that can also be known as cam gear... So if that's the case they will be degreed
Old 03-18-2015, 02:27 PM   #18
Panther140's Avatar
It definitely sounds that way to me
Old 03-18-2015, 06:59 PM   #19
Don't adjust the throttle screw just get a tune. When the car first gets started it will idle fine. Once you begin to press the gas and drive it will stumble and want to stall until its tuned. I'm getting mine tuned this Friday. Here is the same cams you have but with ported heads. Yours will sound similar but probly not as loud because my ported pi heads. I would not drive it much until it's tuned by a professional and defiantly don't get on it If you do drive it without a tune.
drivability of ghost cam tune? r00st 2011-2014 Mustang GT 76 03-01-2018 09:46 AM
Help with cam drivability keeney35 1996-2004 Mustang GT 12 02-14-2015 08:45 PM
mustang drivability issue wss003 1979-1995 Mustang GT 2 11-02-2011 08:14 PM
68 Drivability Issues Shanes0406 Classic Mustangs 6 05-17-2011 07:38 PM
06:41 AM
