Cars jerking - Mustang Evolution
Old 03-18-2015, 03:33 PM   #1
Jay180's Avatar
Cars jerking
So at high speeds and/or I floor it at high speeds my car jerks. This used to happen when I had an exhaust leak but I fixed it. Any other problems causing this?
Jay180 is offline   Reply With Quote
Old 03-18-2015, 04:08 PM   #2
Panther140's Avatar
Does the engine RPM change erratically?
High engine speeds? or high vehicle speeds?
Could be anything from driveline slop to a misfire weak fuel pump messed up clutch or some EFI problem
Panther140 is offline   Reply With Quote
Old 03-18-2015, 05:58 PM   #3
Jay180's Avatar
Well my TOB has been making a noise and it's at around 70 mph is when it starts so if I floor it at 70 it'll jerk a little.
Old 03-18-2015, 06:00 PM   #4
First of all, scan for any trouble codes.
Like Panther said, it could be a lot of things, but if there are no codes, I would check the charging system first, and then do a fuel pressure test.
Old 03-18-2015, 08:16 PM   #5
Panther140's Avatar
What do your RPMs do when you floor it?
Old 03-18-2015, 09:20 PM   #6
Jay180's Avatar
Go up the same speed. The needle doesn't stop or slow down, I'll double check.
Old 03-18-2015, 10:48 PM   #7
This happened to me and it turned out the tip of the spark plug broke off. Also when i changed my plugs i changed the wires (03 v6) And that fixed it.
The car would jerk at highway speeds or under a heavy load so might want to check that
Old 03-18-2015, 11:12 PM   #8
Jay180's Avatar
I'll check my spark plug, I have some new ones ready to go in so if that's the issue it be easy.
Old 03-19-2015, 12:13 AM   #9
Also some people here told me to check the fuel pressure and the fuel filter
Old 03-19-2015, 08:32 AM   #10
Panther140's Avatar
Yeah check them plugs man. start out with the really basic stuff like plugs, coolant, oil, and battery test.
Any of those things can cause it to run bad. Overheat and detonate or just plain old misfire.
Old 03-22-2015, 09:35 PM   #11
Jay180's Avatar
I changed my plugs,check coolant and oil. I know my battery is good, but I'll still do a test just in case.
Old 03-23-2015, 05:02 AM   #12
fenixignition's Avatar
if you are at low rpm, say 35mph at 4th gear (stock gears assuming) and then you floor it, does it stutter and shake? or does it just grunt and try to accelerate slowly?
2002 GT 5sp. 16x,xxx miles
hard hesitation, and jerking jorge gonzalez 2.3 Mustang 0 05-03-2013 07:05 PM
Buying new car/ jerking/ question/ freash meat JonnyBoy101 Pre-2005 V6 Mustang 27 02-06-2013 05:13 AM
Jerking at low RPMs sLbxO143 General Mustang Discussion 0 12-07-2012 03:09 PM
Loss power and overheat, jerking, please help!!! kevpar07 Pre-2005 V6 Mustang 4 09-08-2007 10:25 PM
jerking problem whitev6stang03 Pre-2005 V6 Mustang 20 01-12-2007 07:44 PM
12:40 PM
