09GT Borla mufflers modified to fit 99GT? - Mustang Evolution
Old 03-20-2015, 04:55 AM   #1
mergejones's Avatar
Hey everyone I got a question my cousin whose a mechanic removed his borlar exhaust from his 09 GT and said that he could install them on my 99 GT.
Do you think the modification is worth it, or should I just go and get a new set that's made for my car. He said all he'd have to do is replace the hangers.
What are your thoughts
Name:	borla exhaust.PNG
mergejones is offline   Reply With Quote
Old 03-20-2015, 05:30 AM   #2
fenixignition's Avatar
If your cousin is a mechanic and has access to a welder, anything can be done. otherwise, you may just be cutting and clamping, maybe using a few exaust adapter pieces to match the sizes. worst case, you need to weld on a piece for the exaust hanger. otherwise you can find a way to hook it to the car with the exhaust straps they sell at the auto parts stores.
2002 GT 5sp. 16x,xxx miles
Old 03-20-2015, 07:24 AM   #3
Lorraine's driver
ab_mach1's Avatar
The piping is a larger diameter than the stock exhaust piping. You could probably cut the Borla mufflers on either side and weld them in place with pieces that will adapt. Just make sure that the shop keeps the exhaust modular and doesn't weld the midpipe directly to the Borla mufflers. This will make it easier to upgrade down the road.
IG: @azurebluemach
Instagram: @ab_mach1
99GT vs. 01GT mcvicar04 General Mustang Discussion 4 07-24-2011 07:35 AM
Advice? 94 and 00 Mustang, with 99GT parts.. NeedSomeMods General Mustang Discussion 9 01-27-2011 01:49 PM
10gt and 05-09gt grills interchangable ronn 2011-2014 Mustang GT 4 05-06-2010 07:17 PM
My 99GT convertable is getting 03 cobra IRS transplant2-2-04 Rick0636 Mustang Audio & Video 22 02-08-2004 11:34 AM
99GT vert/03Cobra IRS Rick0636 Pre-2005 V6 Mustang 31 01-12-2004 09:17 PM
09:23 AM
