OSS sensor - Mustang Evolution
Old 03-20-2015, 10:00 AM   #1
Rich04's Avatar
OSS sensor
My speedometer went out (i have a T56) where can i find the OSS sensor? Is it a dealer part?
Thanks in advance
Rich04 is offline   Reply With Quote
Old 03-21-2015, 02:15 PM   #2
You will probably end up having to go to the dealership. But, in any case, I would only use a Motorcraft sensor.
Old 03-21-2015, 07:55 PM   #3
Any auto parts store or rockauto or amazon or wherever. I have used white box sensors with no problems. Its also so easy to change that if it is bad its like 5 minutes to jack the car up and swap it out.
You also could have just... google "mustang OSS sensor" and already had your answer.
Old 03-21-2015, 09:31 PM   #4
Rich04's Avatar
I did that, all i got was VSS sensors. Getting it through the dealer 36$
Old 03-22-2015, 08:42 AM   #5
They will still be listed as a vehicle speed sensor but anything 99- up will be an oss sensor. You can't go wrong with oem tho.
Old 03-24-2015, 01:12 PM   #6
Rich04's Avatar
Changed the sensor still speedo don't work
Old 03-24-2015, 01:17 PM   #7
Rich04's Avatar
Old 03-24-2015, 01:38 PM   #8
You may have a dead speedo or a break in the wire somewhere.
Old 03-24-2015, 04:36 PM   #9
Rich04's Avatar
Every other gauge is fine, followed the wires didn't see anything i noticed the car has a speed calibrator, and i have the tune for the gears could that be a problem?
Old 03-24-2015, 04:50 PM   #10
That is the likely culprit. Remove the speedcal if you have a tune.
Old 03-24-2015, 07:28 PM   #11
Rich04's Avatar
Removed, didn't change anything running outta ideas here
Old 03-24-2015, 08:00 PM   #12
You're going to have to shoot the wires and see if you are getting signal to behind the cluster. If you are, it is likely a bad speedo.
Where is the bank 2 sensor 1 oxygen sensor located? BIG R 2005-2010 Mustang GT 2 10-04-2013 04:46 PM
crank angle sensor/camshaft position sensor instalation 1996v6stang Pre-2005 V6 Mustang 0 11-03-2011 05:57 PM
Camshaft Position Sensor Clint Pre-2005 V6 Mustang 15 02-10-2011 12:30 AM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
DPFE sensor MUSTANGJUNKY420 Pre-2005 V6 Mustang 3 08-01-2003 09:15 PM
09:56 PM
