iac valve - Mustang Evolution
Old 03-20-2015, 06:25 PM   #1
robin_gt's Avatar
iac valve
Hi folks,
so today while coasting to a red light the car just stalled out mid-way.
this also happened before a bought a new iac about 3 months ago from rock-auto for like $90.
the car also takes a couple turns to start which started 3 weeks after i bought the damn iac, i tried returning it but they said that they only take returns within 2 weeks or something like that.
Now i have to give it like half throttle for the car to start normally.
Should i just invest in another iac or is there any other way to fix it.
The new iac is also very loud almost like a vacuum leak but i checked all the hoses and they are all in place and in tact.
Any ideas?
Oh btw its an 02 gt.
robin_gt is offline   Reply With Quote
Old 03-20-2015, 07:13 PM   #2
Panther140's Avatar
IAC? You mean those 2 screws on the front of my carburetor? lol
Panther140 is offline   Reply With Quote
Old 03-20-2015, 07:31 PM   #3
robin_gt's Avatar
idle air control valve sits on the throttle body lol
Old 03-20-2015, 09:21 PM   #4
fenixignition's Avatar
he knows exactly what it is.
you dont still have your old one, do you?
2002 GT 5sp. 16x,xxx miles
Old 03-20-2015, 10:34 PM   #5
If you bought a Motorcraft IAC, I believe that they have a one year warranty.
You'll probably need to call Rockauto to find out if it is still under warranty and for return instructions.
Old 03-21-2015, 10:29 AM   #6
robin_gt's Avatar
i still have the old one i just have to watch the rpms when coasting to a red light
Old 03-21-2015, 10:32 AM   #7
robin_gt's Avatar
iac valve
true the only problem is i dont have the original box...
Old 03-21-2015, 04:04 PM   #8
Ok so theres still an obvious difference between the new and the old. Makes it easier to rule it out. That really sucks tho. Sounds like the plunger is stuck. You dod a reset and relearn when you installed it, right?
Sent from my LG-D800 using Mustang Evolution mobile app
Old 03-21-2015, 05:18 PM   #9
robin_gt's Avatar
truee i didnt do that, if i reset the computer do i have to retune the car with my bama tune, or does the tune stay?
Old 03-21-2015, 07:21 PM   #10
im pretty sure it should stay on there. its flashed in. it should just go back to how it was the day you flashed the bama tune on it. i dont know the details, but i know the stock tune has to relearn its idle and what not. id imagine its the same with bama tunes.
Old 03-21-2015, 07:29 PM   #11
Slater2111's Avatar
It is part of the keep alive memory.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
iac valve alternator 04__gt 1996-2004 Mustang GT 5 11-20-2013 08:31 PM
IAC Valve? Grrrr.... 1996-2004 Mustang GT 4 11-19-2013 10:31 AM
IAC valve mod... finally Just_John Pre-2005 V6 Mustang 0 09-04-2013 07:05 PM
Cleaning IAC Valve '02 V6 sebasflorez Pre-2005 V6 Mustang 4 08-13-2013 08:34 PM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
08:37 AM
