Mil eliminators vs turning rear 02s off - Mustang Evolution
Old 03-22-2015, 12:26 PM   #1
alecas447's Avatar
So rear sensor on bank 2 is stuck lean.
However car is running normal. But every week mpg is decreasing from city 15 mpg a few weeks ago I'm now at about city 11 mpg now.
I didn't now that a rear 02 sensor can cause especially if running lean.
I have 3 options to try and cure this.
1. Mil eliminators. Removes cel. However will the car still run lean with these? Or does it simply ignore the codes.
2. Buy a new rear sensor and hopefully it goes away. And I that's not the issue I'm back at square one.
3. Turn off the rears. But how can I do this? And will turning them off have any effect on the car and if so, will still run lean with the 02s off?
Suggestions or opinions greatly appreciated.
alecas447 is offline   Reply With Quote
Old 03-22-2015, 12:45 PM   #2
natestang07's Avatar
Honestly man sounds like you need a tune to dial in the afr and turn the rear o2s off at the same, time. You just have the off road midpipe?
Old 03-22-2015, 12:49 PM   #3
First of all, the downstream 02 sensors are "test only". They do not provide any engine management data to the PCM.
What is the number of the code that keeps occurring?
Old 03-22-2015, 12:50 PM   #4
Should have a code for cat failure or something of the sort
Old 03-22-2015, 12:56 PM   #5
alecas447's Avatar
Nope I have catted x pipe. Which make it all the more confusing.
And it's there since I installed the x pipe
Name:	ImageUploadedByMustang Evolution1427050554.904769.jpg
Old 03-22-2015, 01:06 PM   #6
http://www.obd-codes.com/p2272
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 03-22-2015, 01:08 PM   #7
alecas447's Avatar
I've seen all that
Old 03-22-2015, 01:16 PM   #8
I figured that you might have.
Since you have been getting this code after you did some exhaust work, I would pay particular attention to the part in the "symptoms" section that mentions exhaust leaks and loose 02 sensors.
Old 03-22-2015, 01:16 PM   #9
alecas447's Avatar
Just don't know what would be the best solution so you're saying the rears have nothing to do with the ecu?
Old 03-22-2015, 01:21 PM   #10
Just don't know what would be the best solution so you're saying the rears have nothing to do with the ecm?
Yes.
It is the upstream sensors that provide the engine management data.
Check for any exhaust leaks first.
This can also be caused by the UPSTREAM 02 sensor.
Old 03-22-2015, 01:32 PM   #11
Yes.
Would bad o2s cause this or a bad connection?
Old 03-22-2015, 01:41 PM   #12
Yes. It could be a bad upstream sensor on that bank.
A bad connection will typically set off a code for the 02 sensor almost immediately.
This can also be caused by a failed fuel injector on that bank.
I would carefully inspect all of the recent exhaust work though, since all of this started to occur after the X-pipe installation.
Old 03-22-2015, 02:23 PM   #13
alecas447's Avatar
I'm going to be changing the mid pipe soon to o/r I'll see what codes I recieve afterwards
Old 03-22-2015, 03:50 PM   #14
alecas447's Avatar
I forgot to ask the mil will that turn the rears off? Or jut ignore the codes?
Old 04-17-2015, 02:45 PM   #15
alecas447's Avatar
Ok so it's been about a week since I replaced the x pipe with an h.
I'm not getting the sensor code anymore which is weird. However I am getting these but I know it's because I'm o/r now. However why isn't the bad 02 sensor showing anymore??? Confused😮😮😮Click image for larger version
Name:	ImageUploadedByMustang Evolution1429303421.915653.jpg
ID:	180305Click image for larger version
Name:	ImageUploadedByMustang Evolution1429303459.909561.jpg
96-04 MIL Eliminators lowering kit Mustang Parts for Sale and Wanted 1 07-18-2008 12:55 PM
MIL eliminators lowering kit 1996-2004 Mustang GT 36 06-03-2008 09:04 AM
MIL Eliminators CakeOrDeath? Pre-2005 V6 Mustang 13 06-11-2007 05:34 PM
MIL eliminators whipster24 Mustang Parts for Sale and Wanted 3 02-24-2005 09:16 AM
99up Mac O/R Hpipe with Steeda mil eliminators. greenflash00 Mustang Parts for Sale and Wanted 2 06-23-2004 11:36 PM
04:32 AM
