Misfiring and sputtering - Mustang Evolution
Old 03-22-2015, 09:43 PM   #1
Vino831's Avatar
I have a 2000 Ford Mustang gt 4.6L I changed spark plugs and cleaned MAF sensor cleaned throttle body flap,new IAC valve,and I cleaned the EGR valve also.Still i get a little misfire and sputtering with shaking when I give it gas. If anyone is going through this or have gone through something similar.please shed some light on my problem.
Vino831 is offline   Reply With Quote
Old 03-22-2015, 10:44 PM   #2
How many miles are on the car?
Do you know if it still has the original coils?
Old 03-22-2015, 11:20 PM   #3
Sea foam
Old 03-23-2015, 05:08 AM   #4
fenixignition's Avatar
no check engine light? it could be a bad coil somewhere. after addressing the coil packs, try to get a compression test done. also, buy the rebuild kit for the coils. its a pack of boots and springs for the coil boots. usually that does it, but you may still need at least one new coil.
2002 GT 5sp. 16x,xxx miles
Old 03-24-2015, 10:44 AM   #5
Vino831's Avatar
It's got over 100k miles on it right now and yes it still has the original coils in it
Old 03-25-2015, 12:32 PM   #6
Stupidstangz's Avatar
Yea get your coil packs changed. I guarantee you that's the problem
Stupidstangz is offline   Reply With Quote
Old 03-25-2015, 10:02 PM   #7
alecas447's Avatar
Bad coil usually emits a cel
alecas447 is offline   Reply With Quote
Old 03-25-2015, 10:07 PM   #8
natestang07's Avatar
Not when it is an intermittent miss under load. My parents expy just had this and it was the cop
Old 03-26-2015, 05:37 AM   #9
mine did that as well. everything seemed ok, no misfired coming up on a cel, but everytime i accellerate, it would struggle and stutter until i get over 2000 rpm, then it would kinda smooth out. changed the suspected coil, and no more issue. I worked at an autoparts store so i kept slappin on different replacement sensors and what not, and nothing else fixed it. swapped a coil, and done.
Old 03-26-2015, 06:59 AM   #10
tfalk's Avatar
99% sure it's a coil as mentioned above... my 99 had the same symptoms. If you can find a shop that has one of the $$$$$ snap on analyzers, it can tell you which cylinder....
99-122 Bright Atlantic Blue S281 S/C Convertible
11-025 Grabber Blue S302 Convertible
Saleen - Power in the hands of a fool!
tfalk is offline   Reply With Quote
Old 03-26-2015, 09:24 AM   #11
Thats how i figured out which cylinder it was because it wouldn't throw a code. But those scanners ain't cheap and most mom & pop shops don't have them so you might have to spend a pretty penny
Old 03-26-2015, 10:08 AM   #12
Vino831's Avatar
Thanks everyone for your comments I will take all of your advices.again Thank you.
05 mustang gt sputtering and shaking Jjhosey 2005-2010 Mustang GT 9 05-31-2014 11:35 PM
Help: Rough Idle and feels like its sputtering during acceleration. brooksyx Pre-2005 V6 Mustang 9 05-13-2013 02:25 PM
Mustang shuttering and misfiring under power MajorPain999 1996-2004 Mustang GT 7 04-24-2013 12:40 PM
Stallin and sputtering NinjaStang Pre-2005 V6 Mustang 17 09-07-2012 09:05 AM
EVAP Help P0455 CEL and now random misfiring 3ntr0py Pre-2005 V6 Mustang 11 01-24-2012 01:37 PM
12:33 PM
