Weird encounter - Mustang Evolution
Old 03-22-2015, 11:23 PM   #1
joe_117's Avatar
Weird encounter
Name:	ImageUploadedByMustang Evolution1427087918.872804.jpg
Okay so here is the story.
I went inside Walmart for about 20 minutes. Came back out, and unlocked my car to get in. I turned the car on and my theft light was flashing while the car was on. Then I turn the car off. Attempt to start it and nothing comes on. No light nothing. So we pop the hood and tap on the batter wires connected to the ground. Then the lamp on top of the car turns on. And my car can start again. Car runs fine, seems like nothing happened. Turn it off and it won't start. So repeat.
My guessing it clean the battery terminal, tighten everything? Etc? Is this a major thing?
Sorry for the book also
joe_117 is offline   Reply With Quote
Old 03-22-2015, 11:25 PM   #2
joe_117's Avatar
Also my gauges do this now. Never done this before.
Old 03-22-2015, 11:27 PM   #3
If it does a full sweep then either your battery or alternator is about to die. As far as everything else i have no clue
Old 03-23-2015, 05:18 PM   #4
joe_117's Avatar
Figured it out. Terminal was loose.
Old 03-23-2015, 08:57 PM   #5
phatspeed7x's Avatar
My 04 also did the exact thing! I replaced the shot loose positive cable clamp, and haven't had any issues since.
~2004 GT with Bolt ons~
phatspeed7x is online now   Reply With Quote
Old 03-23-2015, 11:12 PM   #6
joe_117's Avatar
Like it did this out of no where. I thought I was about to spend over 100$ what's weird was the gauges tho.
Old 03-24-2015, 05:42 AM   #7
fenixignition's Avatar
are you talkin about how you turn the key and the gauges all move to their max position, then drop back to zero? that happens whenever you pull the battery.
2002 GT 5sp. 16x,xxx miles
Old 03-24-2015, 07:49 AM   #8
Panther140's Avatar
I swear to god EFI was designed by tow truck companies. But I suppose when they say "once you go efi you never go back". I think it means "once you go EFI you never make it back home" ! lol
Score card of the causes for times I have been stranded:
Computer issues - 4 (each caused fuel injectors to not work)
Engine failure - 0
Transmission - 0
Clutch - 0 (once had it fail completely but I still made it home)
Carburetor - 0
EFI fuel pump - 1
carb fuel pump - 0
Hmm, im noticing a ****ing pattern here!!!
Panther140 is offline   Reply With Quote
Old 03-24-2015, 10:19 AM   #9
Speed_Mister's Avatar
Region: Arkansas
Check your terminals usually a loose ground on the batter will cause this.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
---------- Post added at 11:19 AM ---------- Previous post was at 11:18 AM ----------
Lol. You got it!
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Corvette encounter? alecas447 1996-2004 Mustang GT 60 04-02-2015 08:51 PM
OMG.. WEIRD.. so weird.. wiarumas The Bar 14 02-17-2005 12:45 PM
03 Cobra encounter Tbird232ci The Bar 3 08-25-2004 09:15 PM
Close encounter... Tbird232ci The Bar 12 08-06-2004 12:30 PM
Weird stuff Ken Pre-2005 V6 Mustang 4 08-10-2003 04:18 PM
07:41 PM
