Putting power to the ground - Mustang Evolution
Old 03-24-2015, 12:23 PM   #1
33wings's Avatar
What mods does everyone reccomend to put their power to the ground? I'm already pushing the engine to the max, now I would like to make sure it's getting to the ground. So what suspension mods does everyone use for drag racing? I have a 2000 GT
33wings is offline   Reply With Quote
Old 03-24-2015, 01:27 PM   #2
tj@steeda's Avatar
What is your budget & what do you currently have on the car from a suspension standpoint?
Feel free to email me at tim@steeda.com for pricing & package support ... we have several drag racers who work in our sales, engineering & manufacturing dept. ... I am sure we can tailor a package to fit your needs!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 03-24-2015, 02:02 PM   #3
33wings's Avatar
I'm just wondering what mods does everyone run that will help me launch and such, I don't have a price range yet
Old 03-24-2015, 02:25 PM   #4
tj@steeda's Avatar
Hello 33Wings,
For a non coil over setup, we recommend using the 555-4101 UCA Steeda 1979-04 Mustang Adjustable Upper Rear Control Arms - Made in USA 555-4101 - Free Shipping!
& the 555-4415 Weight Jacker LCA Steeda 1999-04 Mustang Adjustable Lower Control Arms - Made in USA 555-4415 - Free Shipping!
The Eibach Drag springs Eibach Mustang Drag Springs (79-04) 121-9310.140 - Free Shipping! and the Anti Roll bar.
Steeda 1979-04 Mustang Anti-Roll Bar - Made in the USA 555-8102 - Free Shipping!
Hope that helps!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 03-24-2015, 02:25 PM   #5
tj@steeda's Avatar
Hello 33Wings,
For rear shocks, Double adjustable QA1 would be the best.
http://www.steeda.com/qa1-double-adj...ks-338-td-706/
A single adjustable would be a lower cost option.
http://www.steeda.com/qa1-adjustable...t-338-mu7855p/
Hope that helps!
Let me know if I can help further!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 03-24-2015, 02:51 PM   #6
The most common setup seems to be:
1. Good quality, welded, sub-frame connectors.
2. Good quality, aftermarket lower control arms.
3. The stickiest rear tires that you can find! Or afford...
I'm not familiar with Steeda control arms but unless the uppers have OEM style rubber bushings, I do not recommend using them, or any other aftermarket upper control arms, without doing some serious strengthening to the upper control arm chassis mount.
Old 03-24-2015, 04:43 PM   #7
Stray is right about the uppers. Aftermarket solid uppers induce very dangerous snap oversteer... Not a good idea. Also car needs to be dropped and new suspension is pretty much required at the age these cars are at anyway.
Old 03-24-2015, 05:51 PM   #8
Define "pushing the engine to the max"
Might help a bit with some suggestions.
Old 03-24-2015, 08:50 PM   #9
33wings's Avatar
What will the subframe connectors do and what do you reccomend
Old 03-24-2015, 08:58 PM   #10
^^^This
There are guys out there who consider every possible bolt on they can throw at a 2V "pushed to the max"..not saying that you are but some reference to your mods and power level will help determine the best applications.
Old 03-24-2015, 09:06 PM   #11
Subframe connectors will stiffen the chassis and reduce body roll to some extent. For the price and install (if applicable) it's worth it imo.
I recommend weld in full lengths over bolt ins. Easy enough to do if you can weld, if not then you're looking at probably an hour's labor to get them welded in.
You may be able to find some cheap off a junkyard car or buy a set online.
what suspension parts to put power to ground?? mhobbs 1996-2004 Mustang GT 8 03-09-2012 04:29 AM
Stereo ground wire location Crispy Mustang Audio & Video 4 10-19-2004 11:02 PM
I have fround my ground effects kit. Dom Mustang Audio & Video 124 07-14-2004 02:21 PM
ABC GTR Style Ground Effect Kit (Project Car Pics Included!) Dom Mustang Audio & Video 29 06-27-2004 02:22 PM
power to the ground? Johnny D Pre-2005 V6 Mustang 7 02-17-2004 02:19 PM
09:23 PM
