Fuel Gauge help - Mustang Evolution
Old 03-25-2015, 01:14 AM   #1
ShawnP's Avatar
Fuel Gauge help
This is my first post on here,
My fuel gauge on my 96 gt 4.6 is always reading full, I disconnected the wring harness and it never moved, I moved the needle on the cluster and it goes back to full.
I have only had this car for about 2 months and it was working then it started reading weird then stuck on full, I am assuming it is the sending unit in the trunk but I do not want to go through all that trouble unless I am sure.
I know if it looses ground it will automatically go to full can anyone tell me which wire on the plug by the tank is for the sending unit ground and which is power so I can do an ohm check and a ground check also any other advice would be great.
ShawnP is offline   Reply With Quote
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Fuel ratio gauge help Ranger052 2011-2014 V6 Mustang 1 06-09-2014 07:16 PM
Help to install Sunpro air fuel gauge Ford_guy1984 1996-2004 Mustang GT 3 09-06-2013 10:28 AM
HELP! Fuel gauge stuck WJL11 Pre-2005 V6 Mustang 3 06-23-2012 05:34 PM
help asap air/fuel ratio gauge install Rstang98 Pre-2005 V6 Mustang 8 03-06-2004 01:17 AM
06:24 AM
