Forged Internals - Mustang Evolution
Old 03-26-2015, 01:05 AM   #1
Forged Internals
Going to turbo my 04 gt up to 500-600 hp so I need to get forged engine parts. Is there anywhere I can get a rotating assembly kit with all forged parts? The stuff is hard to find.
epeder is offline   Reply With Quote
Old 03-26-2015, 01:28 AM   #2
2 Stangz's Avatar
Region: Nevada
Maybe try MMR?
Modular Motorsports Racing
Old 03-26-2015, 10:02 AM   #3
I wouldn't trust MMR
Old 03-26-2015, 01:13 PM   #4
Panther140's Avatar
Why would you not trust MMR? Just curious.
Panther140 is offline   Reply With Quote
Old 03-26-2015, 01:22 PM   #5
They are really hit or miss with their parts and customer service.
Old 03-26-2015, 01:25 PM   #6
Panther140's Avatar
Oh I see. Where would you recommend going for a forged rotating assembly?
Old 03-26-2015, 01:29 PM   #7
natestang07's Avatar
Beefcake racing is a name I see thrown around when it comes to forged rotating assemblies
Old 03-26-2015, 11:56 PM   #8
Also will I need to replace drivetrain components such as axles to stand the 500-600 hp?
Old 03-27-2015, 07:09 AM   #9
If you are asking these questions, I highly HIGHLY encourage you to sit down with a calculator and look at how much this is actually going to cost/what it is going to entail. I'm not trying to be an *** or discouraging or anything... but you are looking at a $20k build for a reliable 500-600whp.
You need to upgrade pretty much the whole car at that level.
Old 03-27-2015, 11:22 PM   #10
Yes I know. Which is why I'm looking more at a care engine now.
Old 03-28-2015, 04:30 PM   #11
I'd upgrade the rest of the car first. Once done you can supercharge your current motor up to about 400rwhp safely and enjoy it while you put together a forged omfg motor on the side. Or just sell what you have and buy a Coyote... will cost the same in the end lol.
Old 03-28-2015, 06:02 PM   #12
bwright1973's Avatar
I called mmr 450 to 550 hp is about 8500 that's a long block no valve covers oil pan intake injectors nothing with that said all said and done just to make the motor start your 10,000 into it that's not counting tune install nada that's just parts to your door! After that the tranny will be next in line to go boom then the rear end if you hook it a couple good hard times then the subframe connectors suspension Jesus it caused me to just rethink what I have and a turbo from on three Is the route Iam going at 10 psi it's mid 400's at the wheels which is more than the stock motor can handle. Local place here all parts included installed tuned driving away is just under 5 grand and that's using a upr k frame and coil overs 90lbs injectors and a 320lph pump and it's intercooled. Just my two cents cause I've been researching for a couple months now and nothing is cheap by any means!!
bwright1973 is offline   Reply With Quote
Old 03-28-2015, 06:20 PM   #13
Steve96's Avatar
The 5k is a good price for the Turbo set up. I would pull the trigger on that if I could get the same deal where I'm at.
---------- Post added at 07:20 PM ---------- Previous post was at 07:19 PM ----------
That's installed, tuned and everything?
1996 GT
Old 03-28-2015, 08:04 PM   #14
Go to on 3's web site click on all you need and look at the price! It's intercooled and that's the blow thru mass air injectors and pump as well as k-frame it's a no brainier
Old 03-28-2015, 11:02 PM   #15
What's done to the rest of the car? Because you can have 400hp all day and you'll still lose to a bolt on car with a good suspension setup in the 1/4 mile. You'll be reeling him in at the end but still. Even just a $1500-$2000 investment in relatively basic suspension stuff should get you to where you want to be.
Old 03-29-2015, 08:21 AM   #16
Well if you don't mind Chinese castings Eagle Specialty Products offers full forged rotating assemblies. The few guys I know running 347's prefer Scat as the tolerances are a bit tighter and while they take a bit more to balance it isn't terrible.
But I don't believe they have offerings for SOHC 2V's.
Old 03-29-2015, 04:33 PM   #17
If you do buy an Eagle crank you had damn sure better get it checked out by a shop. Scat is better x1000. Eagle is meh enough to the point that when someone is trying to sell a motor built with the stuff its actually a negative.
Old 03-30-2015, 02:47 PM   #18
Anyone have a link to a crate engine that would support 500 hp?
forged internals dhktactical Pre-2005 V6 Mustang 0 05-23-2012 07:48 PM
forged internals allen1998gt 1996-2004 Mustang GT 6 05-20-2012 03:47 PM
forged internals br10301 1996-2004 Mustang GT 2 02-28-2012 10:48 PM
Forged internals Blackedout Pre-2005 V6 Mustang 29 02-22-2012 04:42 PM
forged internals!? 97V6stangct Pre-2005 V6 Mustang 2 01-19-2012 02:59 PM
06:26 AM
