Turn signal's dont work at all - Mustang Evolution
Old 03-27-2015, 04:49 PM   #1
So my 2002 Mustang GT been at a paint shop for the past 2 months (I wasn't happy it was that long) and the car went without headlights or taillights. Now that its back I tried reinstalling everything and none of the blinkers work. No sound,no arrow, 4 Ways do nothing. Obviously the paint shop said they didn't touch anything. I know it worked before hand so any advice what to check?
Tried checking the fuse's they look fine nothing wrong, just kinda lost. Thanks
MustangShaun12 is offline   Reply With Quote
Old 03-27-2015, 05:20 PM   #2
The electronic flashers are located in locations #13 and #18. I think that one of them is for the four-way flashers and the other is for the turn signals.
If you get a probe-type 12v electrical tester, and a wiring diagram for your car, It shouldn't be too difficult to trace where the problem is in the circuit.
straybullitt is online now   Reply With Quote
Old 03-27-2015, 06:23 PM   #3
WJL
when you have nothing at all 9 times out of ten its a ground problem, could be wrong
WJL is offline   Reply With Quote
Old 03-27-2015, 06:23 PM   #4
Okay I'll recheck those 2, and i read something about the turn signal relay? Do you know anything about that?
Old 03-27-2015, 06:26 PM   #5
Do you know where the ground is located? Sorry i don't know a whole lot,just basics. My brother and dad actually know things.
Old 03-27-2015, 06:39 PM   #6
Do the emergency flashers work?
Old 03-27-2015, 06:52 PM   #7
No nothing works at all. No sound from the blinker,arrow or emergency flashers
Old 03-27-2015, 06:55 PM   #8
WJL
Well you should start with the simple stuff first Check all bulbs make sure they are good.
Take them out, clean the socket at that point if you ave a voltage tester you can check each of the terminal to ground find a bolt in the wheel well area or somewhere on the car if you see a black wire that is a ground and you can use that.
If no voltage start working back to the fuse block be sure to test all functions Brakes, turn signals and parking lights
Good Luck
Old 03-30-2015, 09:22 AM   #9
Jbone007's Avatar
Sounds like you had it taken apart to get painted, check the connectors they may have paint / dust from the paint shop since it set there for so long. But I am leaning to the Fuse's or grounding issue since none of them work!
Jbone007 is offline   Reply With Quote
Old 03-31-2015, 09:19 AM   #10
Panther140's Avatar
Id assume its a ground. My car had a bad ground and the left blinker would only work half the time.
then one day I hit a really huge bump and it works 100% of the time now haa
Panther140 is offline   Reply With Quote
Old 03-31-2015, 04:08 PM   #11
Do your wipers work?
aero86 is offline   Reply With Quote
Turn signal wont work Cobrajet207 SVT Mustang 0 11-01-2012 02:47 PM
96/04 combo turn signal switch Cobra GT Mustang Parts for Sale and Wanted 1 04-17-2009 08:53 AM
frozen turn signal ceilingguy Pre-2005 V6 Mustang 2 04-10-2009 01:34 AM
turn signal prob gearbanger67 Classic Mustangs 2 10-09-2007 08:37 PM
Sequental Turn signal Discount till the 9th!!! Rellik Mustang Audio & Video 2 11-10-2003 11:04 AM
01:48 AM
