Maximum Motorsports coil over kits - Mustang Evolution
Old 03-27-2015, 05:45 PM   #1
Okay looking into coil overs and see coil over kits from Maximum Motorsports. Not exactly sure what I am looking at hah they appear just to be for the fronts. If any one has went this route could you guide me in what kits and what spring rate for aggressive daily driving I would want to consider. Thanks
Hello is offline   Reply With Quote
Old 03-27-2015, 05:58 PM   #2
I run Maximum Motorsports kits. I'm about to go out to eat, but i'll try to remember to come back and post some pics and talk about them.
Old 03-27-2015, 06:04 PM   #3
did you purchase them rite from MM? lmr only has the front kit on there site
Old 03-27-2015, 06:09 PM   #4
I got them from MM. I got both front and rear. For the KONI shocks and struts.
Old 03-27-2015, 06:11 PM   #5
I assume cc plates are the only other purchase I need to make if I pick up the kits?.
Old 03-27-2015, 06:25 PM   #6
You will also want to get your fenders rolled if you go really low.
What other suspension mods do you have?
Old 03-27-2015, 06:31 PM   #7
This is just the beginning. Was looking at shocks, struts, springs, cc plates.ect.
and for not much more could go with coil overs and have adjustability.
Will also be getting lower control arms at the same time and eventually a set of sub frame connectors once I find someone who can weld them in properly.
Old 03-27-2015, 07:13 PM   #8
Subframe connectors should be first
Old 03-27-2015, 07:25 PM   #9
yeah, I hear they make quite a difference!
Unfortunately they are not something I can install myself and I live in a small town and any mechanic in a reasonable distance would probably just be winging the installation. they will be on the list of to do's for sure though.
Old 03-27-2015, 07:43 PM   #10
They are pretty easy. I had help with a friend who can weld. We did them in his garage.
The chassis is extremely bad in these cars. It's more a factor of structural stability and reliability than anything else. Nothing worse than a twisted frame.
Old 03-27-2015, 07:57 PM   #11
what spring rate did you go with?
MM says I will need to buy an additional lower shock mount or a pan hard bar to complete the coil overs.
so the
front kit
rear kit
shocks/struts
cc plates
lower shock mount.
and then lower control arms and sub frame connectors should be next on the list to complete the suspension.
Old 03-27-2015, 08:07 PM   #12
The_Chech's Avatar
so the
front kit
rear kit
shocks/struts
cc plates
lower shock mount.
The reason why you need new shock mounts is because your now putting your spring on a spot it wasn't designed to handle that kind of load. Running their Panhard bar on these cars dramatically increases responsiveness and predictability of how the car will react in hard turns. It's also relatively easy to install really took me and a friend a few hours because we wanted to get it spot on.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 03-27-2015, 08:14 PM   #13
maybe in the future but another 400 for the pan hard and then the diff cover. that's a bit more then id like to spend rite now hah the coil overs vs springs are already taxing me. but in the future I could always revisit it and get the panhard
Old 03-27-2015, 10:03 PM   #14
The Panhard bar was the most noticeable mod I've done. Even more than the coilovers.
And I run 375# front and 250# rear.
Maximum Motorsports front control arms fastmustangs1 Pre-2005 V6 Mustang 3 02-17-2005 04:36 PM
Maximum Motorsports steering rack bushings fastmustangs1 Pre-2005 V6 Mustang 1 10-22-2004 04:16 PM
06:02 PM
