Coil on plug question?? - Mustang Evolution
Old 03-27-2015, 05:48 PM   #1
bwright1973's Avatar
Are the cop cylinder specific or will they work on any cylinder
bwright1973 is offline   Reply With Quote
Old 03-27-2015, 05:53 PM   #2
they are not specific they will work in any order
Hello is offline   Reply With Quote
Old 03-27-2015, 05:55 PM   #3
They are interchangeable and will work on any cylinder.
Old 03-27-2015, 06:04 PM   #4
Thanks guys! I thought so but about the time I started pulling them off I was like damn what if!! Lol what's a normal gap on the plugs??
Old 03-27-2015, 06:09 PM   #5
Name:	ImageUploadedByMustang Evolution1427501338.670842.jpg
ID:	178546Click image for larger version
Name:	ImageUploadedByMustang Evolution1427501355.772746.jpg
Old 03-27-2015, 06:13 PM   #6
.054
Old 03-27-2015, 06:23 PM   #7
Chasing a problem that's kicking my *** and two mechanics! I have a miss at 1400 to 1800 rpms at barely any throttle it also does it sitting in the driveway and it has a nervous idle. Duty cycle on the fuel pump should be around 75% mine is running at 95 to 115% that screams a bad fuel pump to me but looking at the plugs they are perfect lean condition would be white! Cars down on power and I promise this is making my head hurt! Any ideas guys anyone had this issue
Old 03-27-2015, 06:34 PM   #8
Do a compression test while you have the plugs out.
Old 03-27-2015, 06:51 PM   #9
Just pulled all the plugs have two that are light white compaired to the restClick image for larger version
Name:	ImageUploadedByMustang Evolution1427503847.714015.jpg
ID:	178549Click image for larger version
Name:	ImageUploadedByMustang Evolution1427503871.841135.jpg
Old 03-27-2015, 06:52 PM   #10
Compression should be what on these engines 150 to 165????
Old 03-27-2015, 06:54 PM   #11
Those look pretty lean.
They ALL look pretty lean in the pictures.
Old 03-27-2015, 07:05 PM   #12
They are light brown two on the passenger side came out pretty white. Like I said on the lap top fuel pumps working it's *** off that being said why aren't all of them white?? Any other ideas?? Iam stressed out I hate trouble shooting!!!!
Old 03-27-2015, 07:06 PM   #13
Yes. Somewhere in that range.
It is more important that all of the cylinders are within about 10% of one another.
Old 03-27-2015, 07:09 PM   #14
You can also get a "loaner" fuel pressure test gauge from an auto parts store and do a fuel pressure test.
Old 03-27-2015, 07:11 PM   #15
My plan was to get on that tomorrow then a leak down test was next in line! On the lap top this little miss or miss fire bounces all over the place no check engine light at all just a rough idle my first thought was a valve issue but that would be all over the engine. Fuel makes since as far as the effect just trying to figure out the cause! I wish the damn check engine light would come on and help this situation out!! lol
Old 03-27-2015, 07:23 PM   #16
Haha.
It will eventually! You are just being impatient and trying to repair your car too quickly. Lol.
Do a fuel pressure test and post the results.
The pressure should be between 30-55 psi and the fuel system should hold it's pressure, with the pump off, for five minutes with less than 5 psi loss.
Old 03-28-2015, 01:38 PM   #17
Changed out the ifs with the proper gap cars running better fuel pressure weather on the gas or idle is 31psi
Old 03-28-2015, 01:41 PM   #18
And after 5 minutes it fell off 2 psi
Old 03-28-2015, 01:48 PM   #19
natestang07's Avatar
Originally Posted by straybullitt View Post
Haha.
Aren't you supposed to be completely unaware of any issue until that light comes on? This guy is trying to get ahead of the game!!
Old 03-28-2015, 01:58 PM   #20
Hard to be unaware when you know there's a problem the lap top shows the effect but no cause.
Old 03-28-2015, 02:01 PM   #21
Yeah, your fuel pump is likely "working it's *** off".
The pressure is barely in specs...
If the fuel filter hasn't been changed in a while, you can try that but I'd start shopping for a new pump.
Old 03-28-2015, 02:05 PM   #22
Haha.
I think that bwright is just trying to keep from having a good story to post in the "Has your Mustang ever left you stranded" thread!
Old 03-28-2015, 02:57 PM   #23
Changed the fuel filter yesterday is had no restriction at all! I want to replace this fuel pump with a high volume as Iam going to turbo the car at the end of the year what the highest volume and stay in tank?
Old 03-28-2015, 03:40 PM   #24
This is going above my level of expertise, but there are ways of running an in-tank, dual pump setup, like a Terminator, but modifications are required to make it all work.
Depending on the horsepower level that you are trying to achieve, you may need to do something like that.
A lot of people use a single Walbro or a SVT Focus pump, for NA applications, which are direct plug and play replacements. They both flow 255 lph, which I believe is good for about 400ish rwhp.
This would be a good time to decide what your fuel requirements will be and make the necessary fuel system modifications now.
Old 03-28-2015, 04:44 PM   #25
Just googled it myself 300 is the largest intank the focus is a 255 the Lincoln aviator is a 255 after that it's pricey like everything else! Lol guys thank you for all the help you have given! At least I know what I need now
Msd Coil or Screamin Demon Coil? NinjaStang Pre-2005 V6 Mustang 33 03-13-2014 11:12 AM
coil pack or coil on plugs? Joe_Roma5 2005-2010 V6 Mustang 11 01-04-2013 09:20 AM
Spark plug and coil pack sudgestions? p1blake04 1996-2004 Mustang GT 11 08-30-2011 05:18 PM
Coil and plug help Dannyb937 2005-2010 Mustang GT 16 06-03-2011 10:18 PM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
12:35 PM
