Clutch slipping what clutch do y'all suggest? - Mustang Evolution
Old 03-29-2015, 12:37 PM   #1
Speed_Mister's Avatar
Region: Arkansas
I'm at 360-370rwhp on nto5rs my clutch slipped really bad in a 4500 rpm launch. What clutch do y'all suggest getting?
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 03-29-2015, 03:13 PM   #2
The_Chech's Avatar
This was the one I was going to put in my Roush once I installed a Vortech. Just make sure you get a Ford OEM throw out bearing and OEM clutch cable as well or you will have issues down the road. Click image for larger version
Name:	ImageUploadedByMustang Evolution1427663595.596861.jpg
ID:	178676Click image for larger version
Name:	ImageUploadedByMustang Evolution1427663613.346160.jpg
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 03-29-2015, 03:42 PM   #3
Region: Arkansas
I also need a 26 input spline upgrade anybody know where I can get just the 26 input shaft?
Full Bolt Ons
370rwhp 470rwtq
Old 03-30-2015, 12:30 PM   #4
Try Pro Force Performance in Atlanta. Or The3650source.com But for your power level you don't need it. The 10 spline is good for around 500hp.
As for a clutch... an Exedy Mach 400 is rated to 500ft lbs and its a good grippy clutch. Just make sure you get an OEM TOB and Pilot from the dealer.
Old 03-30-2015, 01:20 PM   #5
Region: Arkansas
I was told I need input shaft upgrade since I'm on radials and launching at 4k-4500 rpm's on radials. People Said my 440rwtq would snap it if I launched and hooked.
Full Bolt Ons
370rwhp 470rwtq
Old 03-30-2015, 04:02 PM   #6
Ah, on drs, yes probably a good idea to do it while it's out regardless.
Old 03-30-2015, 05:37 PM   #7
I've got the Exedy 400, great clutch for the price
Old 03-30-2015, 06:14 PM   #8
Panther140's Avatar
If your clutch is slipping from too much power, you're gonna want to beef up your transmission a bit before you get a clutch that will transfer that much power to it. Clutch is a safeguard for your tranny
Panther140 is offline   Reply With Quote
Old 03-31-2015, 08:27 AM   #9
Not really... the T45 and 3650 can both handle more power than he is making and what he is making is more than the stock or a stock spec clutch can take.
Old 03-31-2015, 11:57 AM   #10
Panther140's Avatar
I suppose. i read somewhere they were capable of 400 ft/lbs of torque. Torque is more relevant to transmissions.
For those that dont know, HP = TQ x RPM / 5252
So you could have a high HP engine with 200 ft/lbs of torque and it wouldn't abuse it. Unless it just flat out spun too fast
Old 03-31-2015, 06:19 PM   #11
You probably read somewhere they are rated for 350. They've proven to be good up to when the input shaft pretzels off which is around 500ft lbs. Obviously, YMMV but they've got big internals that can take a lot of abuse. A simple 3650 rebuild with the updated stock internals and 26 spline shaft is good for a ****ton of power.
Old 04-01-2015, 01:02 AM   #12
Region: Arkansas
I'm probably making 450rwtq on a really good dyno run.. Got any links to 26 spline input shaft? I'm probably gonna buy whatever "steal deals" I can find on eBay like I usually do for parts. I'm thinking McLeod clutch or stage 3 spec whichever I find I'm thinking stage 3 is more suitable for my power levels and launching?
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 01:04 AM   #13
Region: Arkansas
Can an exedy 400 handle my spirited driving?
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 05:06 AM   #14
If I were you and was going with Exedy, to play it sage I might just go with the Exedy 500.
Old 04-01-2015, 06:54 AM   #15
Or just jump to the Mccleod rst. The Exedy 400 with the 11 inch flywheel is good for 500ft lbs though.
Old 04-01-2015, 08:21 PM   #16
Region: Arkansas
At the flywheel is what it is rated I believe, but I'm
Not sure... I know when my motor goes I'll get it rebuilt might as well go with exedy 500 for in the future when I bump up hp shot.
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 08:22 PM   #17
Region: Arkansas
Now which fly wheel? Sr is $100, but is it any good? Kinda looking for something about $250 so I know it's at least some what good quality. 300-400 seems to much for flywheel.
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 08:27 PM   #18
Region: Arkansas
I'm gonna buy just the input shaft from Steve at pro-performance, get the exedy 500 then decide what flywheel start saving and collecting parts. Then by the end of the semester I should have the money to pay my buddy to do the labor for $400 they quoted me.
I was thinking about getting subframe connectors and torque box reinforcements. I want to be able to do a 4500 rpm clutch drop, hook, and not break anything. I already got the built 31 spline moser axles and a good diff.
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 08:51 PM   #19
Panther140's Avatar
Thats gonna be sweet! does anybody know if the stock driveshaft assembly can handle that much of a launch? I have always wondered how much they can take
Old 04-01-2015, 08:52 PM   #20
Get an OEM flywheel off a Coyote crate motor. You can get them brand new for $100 if you bang around the classifieds on various forums. Its the same as a modular flywheel minus the dowel pins which you just punch out and install the correct stepped ones for your year.
If you want a futureproof clutch... might want to get the McCleod RST like I said. Pricey but its good for something like 750ft lbs and pedal feel is stock.
Uh yeah you NEED to get that done. If you've been launching like you say at your power level with no subframes and stock boxes you may have already tweaked/broke something.
Old 04-01-2015, 08:58 PM   #21
Region: Arkansas
Nope no damage my clutch was slipping to much right off the launch only got 2.1 60fts haha. Only thing I suspect is my lower control arm bushing may be blown out since my rear alignment is off a tad bit. I probably will get the $75 subframe off of UPR since they come with lower torque box enforcements.
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 09:01 PM   #22
Region: Arkansas
I totally forgot about the driveshaft.. Gosh dang you 2v and all your torque... anybody know if my stock driveshaft won't twist up on me like those twist chips? 2v = lots of stupid upgrades for such a low power level. Anything else I need to look into buying?
---------- Post added at 10:01 PM ---------- Previous post was at 10:01 PM ----------
Will a coyote flywheel fit the tr-3650?
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 09:15 PM   #23
Panther140's Avatar
only other thing I can think of is double check on the axles. Did you alrady mention those? and keep an eye on fuel pressure. idk how much the EFI pump can flow.. cuz I doesnt has efi
Old 04-01-2015, 09:25 PM   #24
Region: Arkansas
Axles are good. I made 6k launches on them from my other car. Only bad thing about my rearend it has a good whine when let off throttle. I have good fuel pressure. I watch my a/f. But anymore power I'm maxing out on my fuel pump duty cycle. I guess I'll have to google max power on stock driveshaft.
---------- Post added at 10:25 PM ---------- Previous post was at 10:24 PM ----------
And you are carb'd?
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 10:00 PM   #25
Panther140's Avatar
And you are carb'd?
Yeah max power might not tell all though. Launching at 4500 and actualy hooking is going to send a really large impulse through the drivetrain lol.
Impulse = Force x Time
So... first we will find force
Force = mass x acceleration
Your 60' is gonna be like 1.7, so lets say your gonna be going 35mph after 60', (or 15.6 m/s for this equation) You're accelerating at 9.17 m/s^2 for that first 60 feet. Thats almost as fast as gravity, which is 9.8 m/s^2
1500kg car X 9.17ms/^2 = 13,755 Newtons
13,755 Newtons X 1.7 seconds = 23,384 Newtons of energy being transmitted through the driveshaft. about 5300 lbs of rotational force on your driveshaft lol
Thats like rapping a cable around it and using it as a pulley to pick up a chevy 1500 quad cab truck by spinning the shaft lol
Old 04-01-2015, 10:15 PM   #26
Region: Arkansas
Sounds like I'll need a driveshaft also...
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 10:16 PM   #27
Region: Arkansas
How broke I'm gonna be the beginning of this summer < how much faster my car will be. It's worth it to me. I just want to get most kinks worked out.
Full Bolt Ons
370rwhp 470rwtq
Old 04-01-2015, 11:00 PM   #28
Panther140's Avatar
Yeah but I dont know what all these driveshafts can handle. I have zero idea how strong they are. Cold be no big deal at all for them tbh.
But yeah, I know what you're saying. The only thing money is useful for is empowering you to do what makes you happy. and basic necessities obviously.
I just got hired at a construction company though. I start working there at the end of the semester and they are giving me 90 hours peer week. I cannot wait. My last job like this gave me 85 per week, but for a lot less $$ per hour. Even at that job I was taking home $1000 every week. So with this job, I will be making some good money. Im gonna stay living with my parents for free and just have my grandpa invest all of my $$ for me. He has a knack for taking $20k and turning it into a small fortune. Its to the point where he makes more money each year from investing than he did as a project manager at fortune 500 engineering firm lol, so im gonna let him play with as much of my money as possible while he is still around and is sharp. And im not talking about the average joe "investing" where people just put their money in a CD or something lol. I think a CD stands for "Certainty of Depreciation" lol. They gain 1% value annually, which is nominal value. Real value terms, you lose 2% real value every year that your money is in a CD because money loses 3% value every year from inflation.
Old 04-02-2015, 10:13 AM   #29
Lorraine's driver
ab_mach1's Avatar
Have you thought about going with slicks? With those kind of launches, I would think they would be a better option. I hear a lot that slicks are easier on the drivetrain. It sounds silly, but the radials have stiff sidewalls and I think that little bit of tire wrinkle provides a slightly more gradual grip.
Instagram: @ab_mach1
Old 04-02-2015, 10:29 AM   #30
Panther140's Avatar
I have heard that also.
Slicks are one of the only ways to make your car faster and also treat your car more gently at the same time lol
Except rocket engines attached to a giant spoiler. it wud be some serious fast and furious badassery to have rocket boosters that launch when you're drag racing. Imagine all the girls you could get
Old 04-02-2015, 06:12 PM   #31
Said it before and I'll say it again, if he's worried about 1/4 mile times he really should be swapping to an auto with a good converter. At his power level it will probably drop half a second off his ET with no other changes. Well... once he gets subframes and a decent rear suspension in there.
Old 04-03-2015, 07:58 PM   #32
bwright1973's Avatar
Center force dual friction with a gold series pressure plate
bwright1973 is offline   Reply With Quote
Old 04-04-2015, 07:20 AM   #33
Yeah until one of those weights sticks or breaks. Serious clutch guys I've talked to say to stay the hell away from centerforce.
Old 04-29-2015, 08:39 AM   #34
Region: Arkansas
Okay so I ordered my McLeod super street 26 spline clutch waiting to order 26 spline input shaft since apparently everybody is out. What clutch quadrant should I go with? I doubt the plastic clutch adjuster can hold this clutch pressure.
Full Bolt Ons
370rwhp 470rwtq
89 clutch slipping.? Vazqueza90 1979-1995 Mustang GT 2 05-11-2013 03:33 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
Clutch slipping?..... Gibby 2005-2010 Mustang GT 3 04-18-2012 12:43 AM
Clutch slipping? Gibby 2011-2014 Mustang GT 10 04-17-2012 08:53 AM
clutch slipping..oh my... eddie1 1996-2004 Mustang GT 4 06-15-2011 09:39 AM
11:08 PM
