Engine is done! - Mustang Evolution
Old 04-02-2015, 01:19 AM   #1
Engine is done!
I have a 2000 mustang gt my engine rod bearings are done my engine has 200000 plus so I just want to get a used engine what are the other ford cars engine that I can used. Any modification required
thanks for any help
jccortez7777 is offline   Reply With Quote
Old 04-02-2015, 01:42 AM   #2
Panther140's Avatar
You can use any ford 4.6 from a ford truck. You have a 4.6 from the windsor plant in that car. the 1999 mustang Gts and the 2000Gts had blocks made in the windsor plant and they have 8 bolt mains that the flywheel bolts to and some other small differences. The 4.6 from the trucks share all of these characteristics, becaue the windsor plant is where they made all the truck engines.
The 4.6s from all of the other cars were made in the romeo plant and use 6 bolt mains, so you would have to get a different flywheel if you wanted to use one of those engines. The only PI 4.6 car engines that got made in the windsor plant are 99 and 00 mustang GT engines, the rest were put in trucks.
Your engine is a PI engine, and you are going to want to replace it with another PI engine. If you're a mustang owner, and dont know what PI is, you should not be doing this job yourself quite yet. But you're on the right track by coming here. There are some very knowledgeable guys on here and they love to help. If a guy called "scottydoesntknow" chips in on this thread, keep in mind that he knows quite a bit about these cars.
The crown vics and grand marquis got the PI heads in 2001 I think
Mustangs got them in 1999
Trucks got them... idk, maybe like 2001 or 2002. Not sure.
But dont buy a non PI engine for ur car. You will lose about 50 horsepower lol.
If you do this job yourself, pay 110% attention to the electrical. Nothing else on this car requires an ounce of skill to do, as long as you don't **** up the wiring somehow. And Ill give you a word from the wise: take the trans out with the engine at the same time on this car. Its a thousand times easier with this unibody car to do it that way. And dont put the engine&tranny back in without a brand new clutch and OEM throw out bearing, if you're talking manual car here.
I just did this project not long ago, like I said. and here is what I learned:
- You CAN put a 2003 crown vic engine in a 1999/2000 mustang GT 5 speed
- You CAN make the 8 bolt flywheel bolt to the 6 bolt mains
-> you can do that because the 8 bolt pattern is actually really similar to the 6 bolt
-> 6 of the holes are very close to lining up, drill them out a tad and it will work
-> Thats only excusable to do if you are a broke college kid and need it done asap
- If the PATS system gets pissed off for no apparent reason, it will turn the fuel pump off after it primes.
I just went through this engine replacement myself a couple months ago. I have the same car as you and I put a Romeo engine in instead of the original Windsor. Not a huge deal, but most people wouldn't have been as crafty as I was about it.
Panther140 is offline   Reply With Quote
Old 04-02-2015, 02:56 PM   #3
If I us a crown Vic engine will I lose power
Old 04-02-2015, 03:42 PM   #4
Panther140's Avatar
No its the exact same engine inside and out.
Its the ford 4.6 PI engine. If you get one from a 2001+ crown vic or grand marquis, you're getting the exact same engine as the 2001 mustang GT
Old 04-02-2015, 04:40 PM   #5
Is it a 6 bolt or a 8 bolt on the crown Vic
Old 04-02-2015, 04:45 PM   #6
Panther140's Avatar
6 bolt on vic.
The only PI 4.6 that had 8 bolt mains in a car (not truck) was the 99/00 mustang GT. The rest of the 8 bolt PI 4.6 are in trucks. all the PI 4.6 cars have 6 bolt mains except yours and mine
Old 04-03-2015, 01:21 AM   #7
For the 6 bolt set up I would need a new flywheels and a new clutch that fits the 6 bolt set up. Would I be able to us my transmission for that set up.
Old 11-01-2015, 09:39 AM   #8
johnathan2225's Avatar
Region: West Virgina
I'm looking for a 6 bolt 164 tooth flywheel that works with a 10.5 diaphragm clutch.. Any ideas? My 4.6 came out of a 2004 crown Vic (intercepter)..
Sponsored at;
http://www.carsponsors.com/dap/a/?a=86212
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 11-01-2015, 10:05 AM   #9
keeney35's Avatar
If you can find a mark viii motor those are essentially cobra motors
04 GT: CAI, 3.73, Longtubes, Full exhaust, FR500 locker diff, Comp Cams 270's, Short throw, Pullies, BBK 73mm TB, MSD coils, 47lb injectors, MPT tuned, Steeda lowering springs, Front strut bar, MM caster camber plates and the list goes on.
keeney35 is offline   Reply With Quote
Old 11-01-2015, 12:48 PM   #10
damn this is such a huge tons of work!!
weiyuhan is offline   Reply With Quote
Old 11-01-2015, 08:30 PM   #11
Mike roush02's Avatar
Engine is done!
I used an 05 crown Vic engine in my 02. It had 6 bolt crank. Bolted right in.
Mike roush02 is offline   Reply With Quote
Old 11-02-2015, 08:31 AM   #12
What was the part number, that's what I got was a 2004 crown Vic with 6 bolt, I just ordered a flywheel supposed to get it on the 4th, the part number for it was M-6375-D46
Sponsored at;
What kind of car wise pranks have you done/ people done to you? Sapphire General Mustang Discussion 74 08-28-2013 05:22 PM
I have a 92 ford mustang shell and want to put in a 4.0 V6 engine. can it be done? merlow26 General Mustang Discussion 4 03-08-2010 11:57 AM
What all has to be done to an engine when installing a higher performance camshaft? holden Classic Mustangs 3 03-06-2010 02:40 AM
finally got my engine done jedwards242000 Pre-2005 V6 Mustang 9 07-13-2007 10:42 PM
another part of blower kit done, and done whipster24 Pictures and Videos 6 03-30-2005 01:02 PM
04:03 AM
