Will i pass inspection with my 93 racetune? - Mustang Evolution
Old 04-02-2015, 07:44 PM   #1
Rich04's Avatar
I need to get the car inspected tommrow and was wondering if my tune is gonna be a problem for a readiness test?
Rich04 is offline   Reply With Quote
Old 04-02-2015, 10:06 PM   #2
Mile high JDF's Avatar
Mine always passed with my secondary oxygen sensors turned off through my tune. I would assume yours would pass just fine
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-02-2015, 11:05 PM   #3
Rich04's Avatar
Was told to put on the 87 tune and put miles on that the 93 wouldn't work thats why i'm asking
Old 04-02-2015, 11:35 PM   #4
Ah gotcha. Honestly I don't see why it wouldn't work. Who tuned it?
Old 04-03-2015, 07:24 AM   #5
Rich04's Avatar
It's just the bama tune
Old 04-03-2015, 07:38 AM   #6
No inspection in florida. Thank god
buddyrich14 is offline   Reply With Quote
Old 04-03-2015, 09:13 AM   #7
Well not sure what the inspection requirements are in your state. As far as the computer is concerned, as long as there are no DTCs you should be fine there. It should also pass a sniffer no problem if you have functioning cats and a visual will not be a problem almost 100% of the time even if stuff is removed (beside the cats).
Old 04-03-2015, 09:53 AM   #8
Rich04's Avatar
I have no cats, my shop does not do a visual, they told me to just set my monitors cause i recently cleared my Out put shaft speed sensor code
Old 04-03-2015, 10:19 AM   #9
Well just make damn sure your shop doesn't do a visual or doesn't have a new guy or isn't getting inspected themselves when you roll in (it happens). But you should def be fine if you aren't throwing any codes and can pass a sniffer if you have one.
Old 04-03-2015, 11:19 AM   #10
alecas447's Avatar
+1
alecas447 is offline   Reply With Quote
Old 04-03-2015, 12:09 PM   #11
Originally Posted by alecas447 View Post
+1
Ours is almost as good for OBD2 cars. Simple DTC scan, visual for cats and gas cap pressure test. Inspection is free and good for 2 years. Having an OBD1 car is a PITA though because they put it on a dyno and sniff check it. Although in 5 years even the youngest OBD1 Mustang will be able to get historic plates and not get inspected anyway. At least in NJ where its 25 years.
How to pass inspection with no cats? Yellow50 2011-2014 Mustang GT 34 06-25-2014 08:52 PM
State inspection pass without cats ? Csinclair1991 2005-2010 Mustang GT 5 11-04-2013 04:56 PM
If I purchase a 1965 Mustang Fastback in N.J. can it pass inspection? cuarto Classic Mustangs 3 08-26-2009 05:16 AM
So my 89 failed inspection... MonteCitan The Bar 18 07-05-2005 10:51 PM
I dominated emissions in my second inspection wiarumas The Bar 4 02-17-2005 04:11 PM
08:07 AM
