Randomly shutting off - Mustang Evolution
Old 04-03-2015, 11:42 AM   #1
Chapka's Avatar
My brother jst got an 04 GT with long tubes throttle body and tuner. Anyway. While driving around it randomly shut down. Any idea or reason why it's doing that?
America is all about speed - hot, nasty, badass speed
Chapka is offline   Reply With Quote
Old 04-03-2015, 11:45 AM   #2
Famine's Avatar
Region: South Dakota
Did he install the throttle body correctly? Vacuum leaks? No cel's right?
Famine is offline   Reply With Quote
Old 04-21-2015, 01:43 AM   #3
99 Mustang GT's Avatar
Does it like sputter or chug before 'shutting down' or does it just shut off out of no where?
99 Mustang GT is offline   Reply With Quote
Old 04-25-2015, 04:27 PM   #4
Chapka's Avatar
Any time you get above 40, left off the gas and coast. It's spit and sputter then die. We re placed the IAC. but now it have really high hanging RMPs
America is all about speed. Hot, nasty, bad *** speed
Old 04-25-2015, 05:02 PM   #5
Post
Did you disconnect the battery so that the PCM can relearn the idle?
Old 04-25-2015, 07:35 PM   #6
+1 ^
Old 06-08-2015, 06:15 PM   #7
Chapka's Avatar
We disconnected the battery. Changed IAC. Still stalls. It is a motorcraft IAC too. What else could it be? When you get off the gas after getting above 50mph. You can watch your RMPs spit and sputter until it dies. Starts right up again tho. You can keep it from stalling by biping the throttle until you put it back in gear or slow to under 50. Mass air flow? Or could it be a fuel problem?
Old 06-08-2015, 06:18 PM   #8
natestang07's Avatar
Tps maybe?
Old 06-08-2015, 06:42 PM   #9
jeno's Avatar
I'm betting tps too
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-08-2015, 07:18 PM   #10
If it is the TPS, there should be a trouble code. Even if the CEL is not lit, there still can be a pending code. So check that first.
What brand throttle body is on the car?
Old 06-08-2015, 07:19 PM   #11
BBK probably
Old 06-09-2015, 02:45 AM   #12
Chapka's Avatar
No codes are thrown. It's the stock throttle body. And what's CEL?
Old 06-09-2015, 04:01 AM   #13
Strange Mud's Avatar
Check Engine Light
Old 06-09-2015, 03:15 PM   #14
Chapka's Avatar
Originally Posted by Strange Mud View Post
Check Engine Light
No CEL. I plugged the tuner into the car and it doesn't pick up anything
Randomly shutting off Apex Predator 1996-2004 Mustang GT 6 02-26-2015 05:44 PM
Gas gauge moves to quarter tank after shutting off car saltysnaks 1996-2004 Mustang GT 4 07-12-2013 08:30 PM
Car randomly shutting off BossFiveOh 2011-2014 Mustang GT 13 06-03-2012 08:56 AM
Car shutting off 93slowstang 1979-1995 Mustang GT 10 08-05-2011 07:40 AM
Shutting off the air bag light? Otlaw80 1979-1995 Mustang GT 8 08-25-2009 12:06 PM
10:29 PM
