96-98 4.6 4v - Mustang Evolution
Old 04-04-2015, 01:47 PM   #1
96-98 4.6 4v
Is it worth swapping a 98 4.6 4v into a 2000 mustang gt ? im thinking about buying one from my uncle complete engine and tranny. Does it need any modifications to swap it in ?
yahua2233 is offline   Reply With Quote
Old 04-04-2015, 05:01 PM   #2
XSlashDashX's Avatar
No modifications needed. Just remember less hp than the 99-04. Nonpi vs pi engine.
Old 04-04-2015, 05:23 PM   #3
Steve96's Avatar
He said a 4valve though so he will pick up quite a bit of power.
1996 GT
Old 04-04-2015, 06:49 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
There are more then one write-ups on this. Google is your friend.. There are some modifications needed, fuel lines, coolant hoses, wiring harness. And other small thing. Easy as far as motor swaps go...
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-04-2015, 07:24 PM   #5
Its a 95% drop in as far as the motor. There will be some "gotchas" depending on what vehicle it is out of. Google is your friend, there are a TON of write ups for Mark VIII 4V swaps as well as the 96-98 4V swaps into GT cars.
Old 04-04-2015, 09:35 PM   #6
Didn't see 4v. My bad
Old 04-05-2015, 11:50 PM   #7
I was wondering if it's worth it because if you have full bolt ons on a 2v then your just looking at like 350hp if your lucky depending on your motor . I'm trying to get it in the 400 - 500 range but that's nearly impossible for N/a and I'm not really trying to go for s/c or t/c . And I also heard that if you stroke it it only adds like 30-50 hp . I just want to know what would be best .
Old 04-06-2015, 05:10 AM   #8
No you don't. You'll make somewhere in the 250rwhp range which is 290-300hp at the flywheel.
Old 04-06-2015, 02:47 PM   #9
Ok so I looked at the motor it actually came of a 99 COBRA so that would be just a direct drop in right ?
Old 04-06-2015, 05:48 PM   #10
It is more like a 90-95% drop in. There are some things you have to do but its not anything you can't do if you are going to be swapping motors anyway.
Old 04-06-2015, 07:24 PM   #11
Holy sh*t, if a full bolt on 2v nets 350 at the fly then I bought the wrong damn car.
Old 04-07-2015, 05:58 AM   #12
260hp+35hp for exhaust+15hp for CAI+15hp for TB/MAF+10hp for pullies+15hp for a plenum=350!!
If you are are a ricer add another 10-15hp for a grounding kit and then 5hp per sticker on the car.
In all seriousness though, a normal "bolt on" car with stock manifolds and a tune is going to put down between 250 and 260 to the wheels which is DAMN good for a 281CI motor with a circa 1997 top end. The 4V does even better with the same time period tech and its not exactly pricey to find an 03-05 Aviator motor to drop in and its REALLY cheap to go the Mark VIII route.
05:58 PM
