96 Gt - Mustang Evolution
Old 04-04-2015, 04:54 PM   #1
96 Gt
I've got a 96 Gt with 3.73 gears, under drive pullies, off road h and Bama tune. I'm having trouble keeping the wheels from spinning in first and second gear. Suspension is stock. I'm planning on getting H&R super sport lowering springs and MM cc plates. Any tips on what else could help?
aero86 is offline   Reply With Quote
Old 04-04-2015, 05:24 PM   #2
Steve96's Avatar
Sub frame connectors and lower control arms, sticky tires will help greatly
1996 GT
Old 04-04-2015, 05:36 PM   #3
LCA for forward and rear? Also do you guys recommend putting isolators on the springs when lowering?
Old 04-04-2015, 07:26 PM   #4
The stock isolators are going to be shot from age so new isolators is a good idea. Some ppl don't run them though. You are spinning because you have 3.73 gears and stock tires/suspension. Lower control arms out back, lower the car, good set of springs/shocks/struts, CC plates, subframes and a good set of wheels and tires and you should be in business.
Old 04-04-2015, 07:52 PM   #5
Well I have somewhat of a hard and squeaky ride. I replaced the shocks and it helped but I'm thinking isolators will help too.
Old 04-04-2015, 08:07 PM   #6
But since I wanna lower the car not sure if isolators will make the drop less.
01:09 AM
