Has anyone heard of mmr adjustable cam sprockets - Mustang Evolution
Old 04-04-2015, 06:57 PM   #1
DetroitMuscle99's Avatar
Causing a p0340 code? I did promaxx patriot stage two heads and stage 3 comp cams over winter. I know the timing is right, reluctor wheel is right, replaced cam and crank sensors and even alternator. Also tested all wiring from cam sensor to pcm which checked out fine. My tuner said I shouldn't of used the modular motorsports racing adjustable cam sprockets and is 99 percent sure that's what's causing it. Before I change them I was also wondering if you guys think this cam sensor is to close or to far from the cam sensor pickup. Was going to try and shim the sensor if so. Upon inspection of the cam sensor there is no marks so it's not touching it but could it still be to close or far from it.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 04-04-2015, 07:22 PM   #2
Did you degree the cams or have them degreed before installing them? As far as the sprockets... most ppl I know who did cams just used the OEM cam sprockets and the Trick Flow adjustable crank sprocket. You don't need to go all crazy like that...
Old 04-04-2015, 07:42 PM   #3
Degreeing the cams on a 2v mod motor is a waste of time. You don't see much gain at all from it. No they were not degreed. I would of used stock cam sprockets but have a Windsor block so they were pressed on.
Old 04-04-2015, 11:51 PM   #4
No... degreeing aftermarket cams is pretty much required. Not for power gain, just to get the car timed properly. Very likely a big part of or the main cause of your issues.
Old 04-05-2015, 06:49 AM   #5
It does help with piston to valve clearance and may help with a more aggressive cam. But that's defiantly not the reason for the cam position sensor code. If there was misfires etc the tuner would of sent me home. Did you look at the cam sensor in that pic? Does it look to close or far from the sensor pick up on that sprocket?
Has anyone heard of Keyport? 93mstnglx The Bar 4 08-26-2013 04:30 AM
GF Performance Chips, has anyone heard of these? jrmustang02 Pre-2005 V6 Mustang 3 07-24-2012 11:07 AM
Has anyone ever heard of a ROUSH 2012 Stage 1 Mustang? Grenville Roush Mustang 3 07-19-2011 06:58 PM
Has anyone heard of Gforce chips KINGCOBRA01 Pre-2005 V6 Mustang 16 06-29-2011 08:35 AM
Has anyone heard of the new Ronaele 300E Mustang? ruhleah General Mustang Discussion 2 04-05-2010 01:53 PM
03:44 AM
