Brake warning light - Mustang Evolution
Old 04-05-2015, 02:16 PM   #1
Brake warning light
When braking from highway speed the light comes on in the dashboard but I have problems...pressure seems good and stops. Any ideas?
Vinnie02 is offline   Reply With Quote
Old 04-05-2015, 02:38 PM   #2
The red brake light, not the yellow ABS light, correct?
The first thing to check is the brake fluid level in the brake master cylinder.
Old 04-05-2015, 02:43 PM   #3
Correct not the abs light...just the red brake light on the dash.
---------- Post added at 08:43 PM ---------- Previous post was at 08:43 PM ----------
Ok will check that level tomorrow.
Old 04-05-2015, 02:51 PM   #4
Keep in mind, a low brake fluid level is most often caused by worn out brake pads. So if the fluid level is indeed low, do some further investigation into the reason for the low fluid level BEFORE you fill up the master cylinder!
Old 04-05-2015, 07:49 PM   #5
Steve96's Avatar
Yeah It's most likely brake fluid being low. Mine did this a couple years ago after doing brakes. It wasn't quite full. Filled it up with about a 1/4 bottle and it has never come back on again and my level has stayed the same Also.
1996 GT
Old 04-17-2015, 06:38 AM   #6
Yep it was the fluid that was a little low. Thanks for the input.
help brake warning light killrocker52 2011-2014 V6 Mustang 7 03-22-2012 10:19 PM
brake warning light.. big man Classic Mustangs 11 01-19-2010 11:54 AM
Brake Warning Light FloMasta24 Pre-2005 V6 Mustang 5 10-21-2006 10:12 PM
03:56 PM
