So the cam/long tube install is finally here.. Just to double check on the cam install tho am I missing anything?
I have the cams, stage 3 comp.. Comp beehive springs, new spring retainers, valve gasket set, and valve stem seal set.. Also have 47lb injectors and it will be dyno tuned withing s few days of the install.. The cams will be degreed.. But do I need new cam adjustable cam sprockets or can just re-key the factory ones since they are bolted on?
You need the TFS adjustable crank sprocket. And the comp cams... they are the 270s right? You will be VERY close for PTV so the cams may have to be retarded a few degrees to clear but if a shop is doing the install they should know this. Hopefully... I personally would have gone with Cushman Stage 2 NA cams myself. Cushman sells the TFS crank sprocket I'm talking about though.
These are what I was talking about. I can't see the link at work because of a firewall but if its a no-name part I would not want it spinning at 6K inside my motor... TFS is all USA made and high quality.
Scotty what he is talking about are adjustable cam gears, they do look like an off brand if it were me i would be looking at "Fidanza" or something like that
Yeah I know he is talking about the cam sprockets but he doesn't need those. You can use the stock sprockets on the cams and then use the adjustable crank gears during the degree process. You can use adjustable cam sprockets if you want but its more $$$ for good ones and I would not trust Chinese **** in the valvetrain. That goes to include Eagle rotating assemblies btw...
I have to agree, the crank gear is a way better way to go, i would always be thinking about the cam gear adjusters coming loose.
From reading the thread it sounds like he is replacing the cams with the engine in the car, not that you cant check piston to valve clearance while in the car, but if you are talking bigger lift along with advancing valve timing PTV clearance should be checked.
I think it would be way easier to do on a stand but that's me. You could figure it out mathematically but i wouldn't be real comfortable with that ether.
My mechanic is pulling the engine and installing the headers and cams... The eBay brand is OBX.. I'm having him install a new tubular k member to help future maintenance.
If you put OBX cam sprockets in your car you are spending $thousands on, you're just as bad as the dude in the other thread claiming to have spent $7000+ on his motor and trying to put an ebay turbo on it. I've seen OBX stuff firsthand, it is dog**** quality.
Use the stock cam sprockets and go with the TFS crank gear. Same result, less money, better quality.
I'd also be HIGHLY suspicious of a builder who would use OBX stuff in a motor TBTH...
I dunno exactly what else you have but new tensioners is always a good idea, obviously all new gaskets etc... But yeah all you need to properly degree them is the degree wheel kit which I'm guessing the shop has, and then the stock cam gears/spacers/washers. I'd do new bolts for the cam gears too, ARP is preferred but new OEM stuff will hold up fine.
I only mentioned it because you didn't list head gaskets in you original post.
You will have to remove and install the heads at least twice if you are going to check PTV clearance and you should do more than just one cylinder IMO.
This is how he's doing mine, mine is going on next
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
