PCM code help - Mustang Evolution
Old 04-07-2015, 07:58 AM   #1
dmcgoy3's Avatar
PCM code help
I am getting a tuner for my car and need the computer code. The sticker inside the door is gone and the computer has been replaced and I don't see the code on the new one anywhere. Is there any other way to find the code or am I screwed?
dmcgoy3 is offline   Reply With Quote
Old 04-07-2015, 09:18 AM   #2
Slater2111's Avatar
You may be able to access it with an OBD2 scanner from orielly. Other than that a good tuner will only write you tunes once you have the tuner in your hand and can access it through the tuner. Then he will take the code you provided off the tuner and write you tunes.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 04-07-2015, 12:09 PM   #3
dmcgoy3's Avatar
I can vaguely remember it being GTG3. I know I took pics of it at one time but I haven't even able to find them
Help! Where is the PCM Part # Located? Dave Bogue 2011-2014 Mustang GT 15 12-31-2013 03:51 AM
pcm code? Am3gross 2011-2014 Mustang GT 4 11-08-2012 02:48 PM
Solution and PCM Help 99ford 2005-2010 V6 Mustang 0 02-04-2012 09:13 PM
PCM question...car's not starting! Oxygenetic Pre-2005 V6 Mustang 2 12-12-2005 05:30 PM
Getting my PCM out Brent Pre-2005 V6 Mustang 5 07-07-2004 09:10 AM
01:07 AM
