CEL and vibration issues - Mustang Evolution
Old 04-08-2015, 08:40 AM   #1
97 Mustang GT 274,000 miles. recent new plugs, wires, coil packs.
1) chronic CEL for almost a year, most common code is P1443. All related components and v lines have been replaced- Purge flow, canister solenoid, etc. Can't get light to stay off. What are we missing?
2) had both engine mounts (one twice) and tranny mount replaced in past few months. I still get a (similar) vibration while in gear (D) with foot on brake. Smooth in neutral or reverse. I never had this before the mounts went bad, but it hasn't gone completely away since replacing them. Is this a transmission issue or still a mount issue?
Thanks for any help.
Mitchet4 is offline   Reply With Quote
Old 04-08-2015, 08:51 AM   #2
fenixignition's Avatar
hows the fluid in the transmission? changed it recently? correct fluid?
2002 GT 5sp. 16x,xxx miles
Old 04-08-2015, 12:09 PM   #3
Fluid
I feel sure it's the correct fluid, I should probably check it myself. I've always depended on the shop to check it with oil changes, but who knows. I had tranny work done at about 230k, so fluid was changed then.
Old 04-08-2015, 12:16 PM   #4
go ahead and do a drain and fill yourself, shouldnt need a full flush. worst case, you will end up with cleaner fluid. if the transmission filter wasnt changed, change that as well. just need a filter kit. inexpensive, comes with the tranny pan gasket, and easy to do. The shudder could be caused by the fluid. there was another thread that talked more about it. if the filter was already changed at 230k, then just do a fluid drain and fill. most people do that every 30k miles. Use a good brand of oil. In my manual, quality of oil makes a big difference. store brand sucked. id imagine its the same with autos.
Old 04-08-2015, 01:56 PM   #5
If you are going to go through the trouble to drain the fuid, you should ALWAYS replace the filter!
You say that you had work done to the transmission... What sort of work was done?
How many miles are on the transmission?
Has it ever been rebuilt?
Old 04-08-2015, 08:41 PM   #6
Transmission rebuild @ 115k, I think it was defective from the factory, repaired at 230k, can't recall what he actually had to fix, but it was jumping in and out of overdrive.
CEL Issues rangerbert 2005-2010 Mustang GT 12 08-07-2013 03:12 PM
Blinking Cel and then stopped blinking on my 2012 mustang gt with less then 400 miles sleeperstatus 2011-2014 Mustang GT 5 05-03-2012 07:16 PM
EVAP Help P0455 CEL and now random misfiring 3ntr0py Pre-2005 V6 Mustang 11 01-24-2012 02:37 PM
CEL and code P0442 TwoSeveN 2005-2010 V6 Mustang 6 08-16-2011 09:15 PM
P0442 and P0456PD CEL OsirisGuy 1996-2004 Mustang GT 4 09-01-2009 12:57 PM
10:38 PM
