P0340 - Mustang Evolution
Old 04-12-2015, 11:18 AM   #1
Jay180's Avatar
P0340
I keep getting this code. I changed my camshaft positioning sensor and alternator it was running fine until recently. I don't know what else to do.
Jay180 is offline   Reply With Quote
Old 04-13-2015, 01:13 PM   #2
Carefully inspect the wiring and the connector to the sensor.
This can also be caused by a failed PCM.
straybullitt is online now   Reply With Quote
Old 04-13-2015, 03:33 PM   #3
DetroitMuscle99's Avatar
I've recently did ported heads and cams and have got the same code ever since. My car runs fine though besides the cel with p0340 code. I replaced alt, cam sensor crank sensor. Still getting code, guessing either I need another harness or a pcm. ****ty deal...let me know how yours works out for you and as soon as mines taken care of I'll let you know what was causing mine. Good luck this codes a nightmare.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 04-13-2015, 10:53 PM   #4
It is often referred to as "The code of death".
Old 04-13-2015, 11:09 PM   #5
Jay180's Avatar
Why the code of death?
Old 04-13-2015, 11:22 PM   #6
Because it can often be a struggle to determine the cause.
Old 04-13-2015, 11:31 PM   #7
509pony's Avatar
Where did you buy the alternator from? Did you ever have the code deleted?
Sent from my SM-T217S using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 04-14-2015, 12:00 AM   #8
Jay180's Avatar
When I bought the alternator the code went away and everything was fine. Then one day it started acting up again it's just a little jerk in high speeds.
Old 04-14-2015, 12:17 AM   #9
It might be a good idea to test the alternator. It wouldn't be the first time that a rebuilt alternator crapped out after a very short time...
Old 04-14-2015, 07:41 AM   #10
509pony's Avatar
I had an issue I bought 2 alternators from autozone and I still jad the issue then I decided to open them up and n oth of them had the wrong regulator I bought one from am and tge issue went away so I jave a problem with rebuilt alternators could be the same issue I
Sent from my SGH-T999L using Mustang Evolution mobile app
Old 04-14-2015, 11:28 PM   #11
Jay180's Avatar
Yeah I'll check out my alternator guys and let you know
Old 04-16-2015, 04:52 PM   #12
My codes gone. Ended up being the adjustable cam sprockets from mmr. My sensor was to close to cam sprocket picking up the 5 Allen head adjust bolts along with the cam sensor bump.
Code: P0340 Jay180 1996-2004 Mustang GT 4 01-30-2015 09:00 PM
P0340 Code :( FortyBrandon 1996-2004 Mustang GT 4 05-30-2013 12:17 AM
Code p0340,0344,0000 and 0345 possible tune problem Jayjay 2005-2010 Mustang GT 1 09-13-2012 07:08 PM
Codes p1401 and p0340 Blackedout Pre-2005 V6 Mustang 0 12-01-2011 04:07 PM
12:25 AM
