Stock '02 ping on 87, 89 seemed to fix it. - Mustang Evolution
Old 04-12-2015, 12:48 PM   #1
v8pony's Avatar
Hey guys, so the last day or so my 02 seems to have developed a pretty serious ping at more than 1/2 throttle between the 2k-3k rpm range. I first started noticed it yesterday when the weather finally decided to warm up a bit. I was running a full tank of 87. After lots and lots of driving yesterday up and down the garden state parkway, I managed to run the tank to E this morning. Well about an hour ago I filled up with 89, and upon leaving the gas station I still noticed the slight ping, after about 5-10 minutes of driving it seems to have next to completly dissapeared 👍. Now could this have something to do with the warm weather and the so called "winter" and "summer" gas? Idk if I should stick with 89 for now on and say screw it, or if I should begin to track down what's causing it to ping on 87. Spark plugs less than 20k, maf cleaned recently, air filter cleaned 6 months ago, fuel filter changed less than 20k. and I am on the STOCK TUNE.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 04-13-2015, 12:52 PM   #2
You didn't mention how many miles are on the car, but here is one thing that can cause pre-ignition.
This is a big block Ford with around a quarter of a million miles on it.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 04-13-2015, 12:58 PM   #3
That carbon gets red hot and acts like a spark plug, prematurely lighting off the air/fuel charge.
You can see a spot that was staying "lit" in this photo.
And, NO, SeaFoam will NOT remove this! It needs to be scraped off of the pistons and combustion chambers.
Old 04-13-2015, 01:03 PM   #4
This may not be your problem but one of the symptoms of this is hyper-sensitivity to temperature changes, requiring more octane the hotter that the OAT gets.
Ping at low RPMs Red Rover 2011-2014 V6 Mustang 7 10-18-2012 12:15 PM
Knock & Ping question ab_mach1 1996-2004 Mustang GT 351 10-12-2012 11:13 AM
Engine "ping" Eeyore General Mustang Discussion 6 04-26-2009 03:07 PM
ping pong... matrix style dark The Bar 8 08-09-2003 05:37 PM
Matrix Ping Pong.. Rellik The Bar 1 07-23-2003 01:30 PM
10:30 PM
