Lowering Springs wear out shocks and struts? - Mustang Evolution
Old 04-13-2015, 08:47 PM   #1
TruBluStang03's Avatar
I am going to be lowering my car pretty soon with lowering springs and I heard somewhere that lowering springs just increase the wear on the shocks and struts. Is this true?
TruBluStang03 is offline   Reply With Quote
Old 04-13-2015, 09:32 PM   #2
The stock ones yes. They are not designed for lowering springs. Go too low and they can bottom out also.
Old 04-16-2015, 08:57 AM   #3
CandymanGT's Avatar
Shocks/struts are designed to work in a designated range of movement. When you lower the car you force the old ones out of their range.
CandymanGT is offline   Reply With Quote
Old 04-16-2015, 09:20 AM   #4
Sterlingbeast5.0's Avatar
it will be cheaper in the long run to just change them out when doing springs. Basically one labor charge instead of two. Plus if you go to American Muscle right now they have a hell of a deal on Koni
Old 04-16-2015, 10:22 AM   #5
Steve96's Avatar
I would get the Konis and get it all at once or you will have to do them down the road anyway depending what condition their in now. If going lower than 1.5" I would Also look into CC plates, and if you do get CC plates, get Nothing other than Maximum Motorsports.
1996 GT
Old 04-16-2015, 11:58 AM   #6
You'll need CC plates too and a good alignment. Unless you want to be tramalining all over the place and buying new front tires every 6 months...
Old 04-16-2015, 07:20 PM   #7
Lorraine's driver
ab_mach1's Avatar
^Yup!
I have first hand experience in making the mistake of getting springs and thinking the stock shocks and struts would work for me. I even got springs that were really close to the stock spring rates on the Mach 1's and still noticed a lack of controlled feel on the road. Plus it hit bumps hard as hell.
I got Koni STR.T's and they are excellent. If you want to go higher performance, get Koni or Tokico adjustables.
Instagram: @ab_mach1
Old 04-17-2015, 10:48 AM   #8
tj@steeda's Avatar
All the above!
Let me know if I can help with a set of Konis & caster camber plates!
We have great deals going on & I can help with further forum pricing.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Lowering springs/shocks and struts Question mustangmar2001 1996-2004 Mustang GT 4 01-05-2013 08:06 AM
struts and shocks or springs dmg1092 1996-2004 Mustang GT 1 06-02-2012 08:07 PM
Best shocks and struts for lowering? Blackedout Pre-2005 V6 Mustang 17 12-05-2011 07:57 AM
shocks, struts, and springs on a 79 notch Taywi Classic Mustangs 8 03-13-2007 11:41 AM
Shocks and Struts with springs? steedav6builder Pre-2005 V6 Mustang 16 07-13-2004 09:42 AM
09:43 AM
