315s rubbing - Mustang Evolution
Old 04-14-2015, 04:14 PM   #1
Yellastang03's Avatar
315s rubbing
Anybody ever had problems with rubbing on 99-04s with 315s without being lowered? I recently put on 315 nittos in the rear and from what I read a 315 35 17 will clear for up to a 2 inch drop and I'm at stock height. I thought my shocks were just really worn out so I replace them with konis (non adjustable) and still getting fender rubbing when Corning with any dip in the road or if I pull into a drive way.
Yellastang03 is offline   Reply With Quote
Old 04-14-2015, 04:45 PM   #2
Mile high JDF's Avatar
I never rubbed and was dropped 2"+ in the rear but that was on an IRS. Try removing your quad shocks and see what that does for you
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-14-2015, 04:54 PM   #3
Now that I think about it they are both leaking slightly. Will removing them make the rear end sloppy at all? From what I understand you can ditch the quad shocks with a upgraded L.C. Arm. But how about taking them off with a stock l.c. arm for now?
Old 04-14-2015, 06:09 PM   #4
fenixignition's Avatar
I would think Would worse. The quad shocks help prevent wheel hop i thought. As for lower control arms, an upgrade may help,but a panhard bar should allow you to eliminate the uca's.
I know it's real thorough info, but hope it helps you know what to look into.
Sent from my LG-D800 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 04-16-2015, 12:13 PM   #5
If you have lower control arms you do not need the quad shocks. You can flip them if you want to keep them, this gets the fat end of the quad shock out of the way of the rim and solves clearance issues regarding the quads.
A panhard bar will allow you to get rid of ONE of your UCAs, not both. You need the torque arm to get rid of both completely and be a true 3 link.
Old 04-16-2015, 07:24 PM   #6
Lorraine's driver
ab_mach1's Avatar
IMO, I wouldn't remove the quad shocks. You'll get wheel hop a lot more often. They do a lot more than just wheel hop, but you'll notice that first. If you don't notice it without them, it's because they were worn out in the first place lol. I'd look at getting your fenders rolled.
Instagram: @ab_mach1
Old 04-17-2015, 07:39 AM   #7
Alright thanks guys. I think I'll get some upgraded lcas and ditch the quads and see what happens.
Old 04-17-2015, 09:01 AM   #8
Slater2111's Avatar
315s rubbing
You won't need the quad shocks with a good set of LCAs. Also stay away from any of the LCAs that have polyurethane on the chassis side mount. Preferably neither side having polyurethane.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 04-17-2015, 12:57 PM   #9
Speed_Mister's Avatar
Region: Arkansas
Leave the quad shocks. Ford installed them there for a reason even with aftermarket control arms. Just flip the fat side of the quad shocks facing the other way from the wheels.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
I need help with 315s on my 2013 gt! Mustang32Bill Mustang Wheels & Tires 1 04-02-2014 08:22 PM
Will 315s fit on my 2013 gt? Mustang32Bill 2011-2014 Mustang GT 53 12-08-2013 11:05 PM
Should I put on 315s? Redsvtcobra SVT Mustang 18 12-03-2013 03:12 PM
Getting some rubbing up front...any suggestions? greenflash00 Mustang Wheels & Tires 18 02-08-2004 12:42 PM
02:40 PM
