clutchnet racing clutch kit and flywheel - Mustang Evolution
Old 04-15-2015, 12:09 AM   #1
I was wondering if anyone out there has had any first hand experience with there products? I have read reviews but I just want to know if anyone can tell there experience
Thank you
jccortez7777 is offline   Reply With Quote
Old 04-15-2015, 07:24 AM   #2
Just checked them out. Way overpriced. Get an Exedy Mach 400 from American Muscle along with an OEM iron flywheel if you are stockish/bolt ons. You'll pay for the clutch and flywheel what you would pay for just a clutch from those clutchnet guys.
Old 04-15-2015, 11:48 AM   #3
Yeah but I know I guy who will sell me a stage 3 with the flywheel for $380 I just don't know if there good or crapy
Old 04-15-2015, 12:38 PM   #4
What year is your car? What type of flywheel as in material and diameter is it? Brand of flywheel? What sort of mods are done to your car and do you need more than a stock replacement clutch/flywheel setup? The stock clutch is good for around 350hp.
Old 04-15-2015, 06:46 PM   #5
2000 with steeda pulleys, Diablo tuner aluminum drive shaft bbk shorty headers flows in the back knn cold air intake Mac 75 mm Trootle and trick flow plenum.
The. Flywheel aluminum and it's made by clutchnet the stage 3 is rated for 620 HP / Torque Capacity: 595 ft/lbs
Just wondering if it's a good brand to invest in?
Old 04-16-2015, 06:30 AM   #6
I've never heard of the brand before honestly and I've been messing with these cars for awhile. $380 for an aluminum flywheel and a good clutch is a good price... but you are a 2000 so you have an 8 bolt flywheel which is the less common type of setup. If this flywheel he has has 6 bolts you can't use it. 1999 and 2000 model year GTs had the 8 bolt flywheels as well as all the Cobras and Manual transmission Mach1s.
What I did with my setup which was a 1999 engine... I found a brand new Coyote flywheel which is an 8 bolt unit and works with the 4.6L motors for $125 shipped on an online forum. You can find them usually for $100 plus shipping. Only thing you have to do is take a punch and knock out the Coyote dowel pins, tap in a $15 set of 4.6L dowel pins and good to go. The Exedy 11" Mach 400 clutch was $239 with a forum discount so I paid about $380 for that setup and it worked great.
That's another thing, always upgrade to an 11" setup unless you have a specific need for a smaller flywheel/clutch like a fast revving autox/road race car. You don't need that for a street car though and a heavier flywheel actually helps keep the RPMs up on the street in a bolt on car.
edit: You also have to look at what materials and everything this "Stage 3" clutch is made out of. "Stage" is just a marketing gimmick and it means precisely nothing as it is not any sort of universal measurement throughout the brands. One brand's "stage 1" could be way better than another's "stage 2", it all depends. I like the Exedy 400s because they are an OEM manufacturer, they engage real smooth, pedal feel is light and the 11" Mach 400 is rated for 500ft lbs at the flywheel. You will never get to that power level reliably on a 4.6L without a built motor anyway.
Also, for your power level if you don't plan on putting a supercharger or nitrous on it anytime soon, you can just get a $125 Luk Gold replacement clutch and resurface the flywheel you have in the car now for $60 and be totally fine. OEM TOB/Pilot will be another $50 or so. You'd be into it for like $225 total in parts if that's all you need. Labor is always the killer on clutch changes anyway since the trans has to come out, that's why I always DIY.
Top 5 best clutch and flywheel ToplessCobra SVT Mustang 18 04-11-2013 11:13 AM
Clutch and Flywheel Help!! GDogg08 Pre-2005 V6 Mustang 0 02-26-2013 09:05 PM
Clutch and Flywheel Stang23 2005-2010 Mustang GT 8 12-16-2011 07:56 PM
Can I use a Ford Racing steel flywheel with a Centerforce clutch kit? Finian 1996-2004 Mustang GT 2 12-15-2011 09:47 AM
Where's the best place to find/buy a new clutch kit and flywheel for a 200 Ford Mustang V6? dunmore General Mustang Discussion 3 04-11-2010 02:50 PM
01:48 AM
