WHAT EXHAUST??? - Mustang Evolution
Old 04-19-2015, 05:44 PM   #1
mustangt03's Avatar
WHAT EXHAUST???
I have flowmasters 40s they drone really bad on the highway and not the sound I'm looking for. I just want it sound good and look good under $500 or lower
mustangt03 is offline   Reply With Quote
Old 04-19-2015, 11:46 PM   #2
Steve96's Avatar
Do you have an off road mid pipe or just flows welded in? I have an off road X with magnapacks welded in and I don't get much drone at cruising speeds, It's tolerable. It has increased since my 410s were installed but still not that bad.
1996 GT
Old 04-19-2015, 11:48 PM   #3
Steve96's Avatar
Flowmasters are known for the drone. Any chambered muffler will give you more drone like that from what I have read. Are you wanting a whole new catback? Cause you could easily get a mid pipe, new mufflers, and have it all installed for under $500.
1996 GT
Old 04-20-2015, 06:11 AM   #4
mustangt03's Avatar
I have stock H pipe and i welded and the mufflers into the stock exhaust, I can do the installation also
Old 04-20-2015, 07:34 AM   #5
They're called Dronemasters for a reason. Get a set of Dynomax Ultraflows. They are $60 each on Amazon I believe. They sound beastly and do not drone. I ran them for 7 years with an OR pipe and aftermarket headers on a 95 Cobra. Always got compliments everywhere I went to the point of even a shop asking wtf they were because EVERYONE else in that area I was in had Flows with the occasional Magnaflow/Bassanni/Borla thrown in.
Old 04-20-2015, 08:18 AM   #6
fenixignition's Avatar
if you need the whole cat back setup, and not just the mufflers, these are pretty good about no drone. Steeda 1999-04 Mustang GT Cat-Back Exhaust - Made in USA 040-13868 - Free Shipping! if you can find them used. otherwise, pretty expensive.
2002 GT 5sp. 16x,xxx miles
Old 04-20-2015, 08:29 AM   #7
Used exhaust is fine provided it is a fully stainless one like a Magnaflow or the Steeda etc...
That steeda catback is a damn good kit too.
Old 04-20-2015, 08:32 AM   #8
Hey, scotty, you know how stock exhaust, cats and mufflers, how over the years, they get clogged and get louder? I was told with high flow cats, not to worry about that. but what about say Borla mufflers from like, 2002? do you think those get gunked up? or is mostly free flowing enough to not be a real issue like stock parts?
Old 04-20-2015, 08:44 AM   #9
I'd leave them honestly. Should be fine. If you are completely OCD you can always remove them (unless welded in) and just take a look.
Only thing I will add to this thread... for a 94-98 car there are MANY catbacks that just look funky with the tailpipes. Flowmaster (and Dynomax Ultras) are pretty much the only kits that have tailpipes that look good on a 94-98 car. 2.5" mirror polished tails for the flows... my 98GT had Dynomax mufflers welded to Flowmaster polished tailpipes and it looked/sounded great.
Other kits will have 2.5" pipe to 3-3.5" tips which looks silly on a 94-98 because you can see the whole pipe.
Old 04-21-2015, 05:11 PM   #10
mustangt03's Avatar
True that ha, yea I want to do cat back so everything looks "clean" underneath. What do you guys think of Pypes pipe bomb?
Old 04-21-2015, 07:11 PM   #11
phatspeed7x's Avatar
I'm currently running my own "built" Pypes pipe bomb cat back on my 04 GT.
-Pypes off-road H pipe.
-Pypes 2.5" mid connecting pipes.
-Pypes M80 race mufflers.
-Custom dual 2.5" tailpipes.
-Stock tips.
If you drive the car "nice" around town it, it doesn't turn too many heads. But once you stomp on it... RACE CAR!
Interior drone may not be any better than what you currently have, but it has plenty of the old school muscle car sound. And that's what I was aiming for. If you can't be fast, might as well be loud!
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 04-21-2015, 09:03 PM   #12
The Dynomax Ultras are real good for being very mild off idle and cruising around at low RPM. Still throaty and rumbly and ppl for sure know its aftermarket but its not crazy. But when you stomp on it... yeah...
Old 04-22-2015, 03:34 PM   #13
mustangt03's Avatar
-Stock tips.
that sounds good ! might do those
Old 04-22-2015, 05:06 PM   #14
Just beware, Pypes uses real thin and very low quality stainless steel and the welds are... well they are what you would expect from a chinese person making 10 cents an hour.
Old 04-22-2015, 05:22 PM   #15
I beg to differ sir. My M80 race mufflers seem to be well built and Pypes back their products with a lifetime warranty. I know I guy who has a violator axle back setup on his 2009 GT. Has held up extremely well.
Old 04-22-2015, 06:06 PM   #16
Put it next to a FRPP or Magnaflow setup. The difference is obvious.
Old 04-22-2015, 06:23 PM   #17
mustangt03's Avatar
Should i just say screw it an go BORLA, lol and terrorze the town
Old 04-22-2015, 06:28 PM   #18
You'll have to buy used for your budget, Borla likes to over charge on their stuff...
Adventure till you drop
Old 04-23-2015, 11:26 AM   #19
Borla is way overpriced. Magnaflow is going to be your best priced "high quality" kit. If you need to have a louder exhaust for whatever reason, the Magnapack exhaust is there for you.
Old 04-23-2015, 11:42 AM   #20
Stay away from pypes. I took them off couldn't stand the junk fitment it was. Trust just spend the extra money and get slp
04sonic is offline   Reply With Quote
Old 04-23-2015, 03:15 PM   #21
Steve96's Avatar
Again I would get a good quality off road x or h pipe then get a Nice set of magnapacks, slp 2s, borla ataks, or stingers. There are literally a hundred different combos you could go with. Then just have the new mufflers welded in unless you have other issues under there where the entire catback needs to be replaced.
1996 GT
Old 04-23-2015, 03:17 PM   #22
WHAT EXHAUST???
^ that's not $500 or lower, new...
Old 04-23-2015, 03:17 PM   #23
Steve96's Avatar
I have a bbk off road x with maganapacks and it Sounds great to me. I may switch to an h though as I do like that sound a little better now and want to change it up a bit too after a few years with my current set up.
1996 GT
Old 04-23-2015, 03:20 PM   #24
Steve96's Avatar
A maganflow catback would probably be over or really close to $500. You can get a UPR x or h new close to $200 or a little under, set of magnapacks for around $170-180, then labor to install and weld those in shouldnt be more than $100-150 (at least around me).
1996 GT
Old 04-23-2015, 04:30 PM   #25
Except stock pipe size is 2.25". Almost all legit catbacks are 2.5" all the way for the 2/3/4V and 3" for the Coyote/GT500.
Old 04-23-2015, 11:09 PM   #26
Steve96's Avatar
True. I don't know how much more performance is gained by the 1/4", but I know it will flow better and also be mandrel bent and clean. I was just giving an option of a cheaper route and to still free it up a lot. If I was seriously trying to suck every last 5-10hp out of it I would go with an actual cat back system. But for me this route worked well, sounds great, and has aged very well so far (no winters on it though).
1996 GT
Old 04-24-2015, 05:46 AM   #27
Actually, the Borla catback is 2.25" or it was in the 2000s, they may have updated it. They claimed their mufflers were so free flowing and the design was so good it didn't need to be 2.5". I have no idea if true and didn't know anyone who would pay the prohibitive cost of Borla exhausts to test out the theory.
If you are trying to do an exhaust on the cheap I would:
-Stainless UPR mid pipe
-Dynomax Ultra Flows welded into the stock pipes
The Ultras are fully stainless, they are free flowing, they do not drone on the highway and they sound GREAT when you floor it yet mild enough to where you won't attract any popo just tooling around neighborhoods. I had them on my 95 Cobra with longtubes and OR pipe and whenever I saw a cop I just pushed the clutch in and coasted by nice and mellow. Dynomax Ultras are also $60 each on Amazon and top notch quality.
Old 04-24-2015, 09:20 PM   #28
alecas447's Avatar
Some people here swear that a 2.5 inch cat back is a lot louder than the stock pipe size
alecas447 is offline   Reply With Quote
Old 04-24-2015, 10:48 PM   #29
By changing to a off-road H pipe from the factory converters made the biggest difference in sound. And now the exhaust flows alot better too.
Old 04-25-2015, 11:03 PM   #30
joe_117's Avatar
I have slp. God dang dude they are loud with my bassani x pipe. I heard it outside of the car and i literally thought it sounded completely different from a 2 valve.
joe_117 is offline   Reply With Quote
Old 04-26-2015, 09:02 AM   #31
SLP is too loud IMO. They're not even mufflers they are just resonators really. I mean if you live out in bum**** Egypt and never drive through a neighborhood or anything I guess but when I lived in my old neighborhood there was a F body with the SLP thing going on and dude would get on it at like 6AM going to work like wtf. It did stop eventually. Either someone said something or dude got a ticket or sold the car or whatever.
Old 04-26-2015, 10:31 AM   #32
Slater2111's Avatar
I have LM1s on mine with a prochamber and it's pretty loud. I leave for school at 530 every morning. I just put it in second and cruise out the neighborhood. No one has ever said anything to me about it.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 04-26-2015, 11:06 AM   #33
joe_117's Avatar
You Are defiantly right on the loud man. I may switch. Magnaflow or bassani
Old 04-26-2015, 05:03 PM   #34
Leaving Walmart today I set off a car alarm. Lol
exhaust
Exhaust Exhaust Exhaust cdouglas12 2005-2010 Mustang GT 10 01-24-2015 09:37 PM
Exhaust is driving me crazy, cant find much on exhaust for 67 Joshy Classic Mustangs 0 01-11-2014 06:54 PM
One exhaust tip a little off after Boss exhaust install mmike87 2011-2014 Mustang GT 6 09-21-2012 07:42 PM
New Exhaust Video......3'' Exhaust WaldoGT07 General Mustang Discussion 0 12-20-2011 07:59 PM
08:06 PM
