New 97 GT ~ First Upgrades - Mustang Evolution
Old 04-21-2015, 08:13 AM   #1
The car is stock, just a cold air intake and flow masters.
Looking to add upper intake plenum w 70mm throttle body to get it breathing right!
My question is;
I ordered a spacer for the plenum - is it worth the cost for using? I would like to do a pi swap in the future.
Any suggestions for other must do mods - I'm not looking to go crazy, but I am new to mustangs!
Thanks!
Kevsworld is offline   Reply With Quote
Old 04-21-2015, 08:48 AM   #2
Steve96's Avatar
The spacer won't net you any gains. At least from what I have researched and read. Congrats on the new car! 410 gears are the one thing that really woke my car up being a 96 npi.
1996 GT
Old 04-21-2015, 08:51 AM   #3
Spacer is a waste, you want a 75mm TB, not 70mm. Get the Trick Flow Plenum/75mm TB combo for $279 from Summit. Better quality that the cheapo ones and USA made, not Chinese copy.
PI swap should definitely be on your list of things do do when you get the basics taken care of. You auto or manual?
Old 04-21-2015, 10:34 AM   #4
Thanks guys!
Steve96 ~ won't the 410s keep me off the highway? I need to make some cross towns commutes -
Scotty - I bought from SR performance - same price for combo - are they not any good?
This has auto tranny
Old 04-21-2015, 12:55 PM   #5
Originally Posted by Kevsworld View Post
Thanks guys!
Depends how fast you want to go on the highway. Get some slightly taller tires and you should be fine or just go 65mph and you'll be fine... Or just rev it. OD in an auto is .70 so you can put that into the RPM calculator (first google result and scroll to the bottom calculator on the page) along with your MPH and tire size of 25.7" to see what you will be spinning. They aren't as bad as ppl will lead you to believe, don't fear the gear.
The SR pieces... they'll be ok but they are Chinese copies of other brands.
Old 04-21-2015, 11:09 PM   #6
Steve96's Avatar
I'm at about 2400-2500 rpms at 70 on the highway, if I kick it down to 65 then It's about 2200 or so. It isn't bad at all honestly. It will effect your mpg though. If you do a ton of highway driving then Maybe go with 373 gears..mine is not a daily. The difference between 373 and 410s was small enough for me just to get the 410s.
1996 GT
Old 04-21-2015, 11:10 PM   #7
Steve96's Avatar
I almost feel like if I went for the 373s I wouldn't have been happy and been wishing I went 410.
1996 GT
Old 04-22-2015, 01:15 AM   #8
99 Mustang GT's Avatar
I'm thinking about getting gears in the next week or so, but mines my DD (manual) what do you suggest I do? I've looked into both and either way it sounds like I'll be happy.
99 Mustang GT is offline   Reply With Quote
Old 04-22-2015, 07:34 AM   #9
allenj125's Avatar
I have 3.73 and wish I went with 4.10s.
I also just finished my PI swap. I rebuilt the bottom end while I was at it.
Sent from my HTC Desire 610 using Mustang Evolution mobile app
allenj125 is offline   Reply With Quote
Old 04-22-2015, 09:39 AM   #10
Steve96's Avatar
How is she after the swap?
1996 GT
Old 04-22-2015, 10:23 AM   #11
allenj125's Avatar
I'm still working with the tune. The swap is acting different with my supercharger.
Old 04-22-2015, 01:03 PM   #12
4.10s, don't fear the gear. If you feel your highway RPMs are too high, jump up to a 26.5" or even 27" tall rear tire. From your username I'm assuming you have a 99 so you have the .68 overdrive.
Old 04-22-2015, 01:17 PM   #13
Well I'm also getting the amr's (ordering Friday) with the 18x10's in the back.
Old 04-22-2015, 06:11 PM   #14
ch0wd0g's Avatar
70mm or 75mm? I heard on the stock GT, if you go with 75mm then there could be issues with the sensors or something like that. Think it was mentioned on one of AM Justin videos.
Make sure get some of the appearance mods too. Makes a world of difference from an eyeball standpoint.
ch0wd0g is offline   Reply With Quote
Old 04-23-2015, 11:09 AM   #15
For the throttle body, 75mm.
And yeah a 94-98 with a nice set of wheels cleaned up and a few appearance mods COMPLETELY overhauls the look of the car.
First new car, first mustang, first ford Sportsman New Member Introductions & Greetings 21 11-20-2015 02:59 PM
First Mustang...First Ford...First Car This Awesome! Debster New Member Introductions & Greetings 13 04-28-2013 12:30 PM
First Three Affordable Upgrades Sobersucks85 1996-2004 Mustang GT 13 06-27-2012 10:16 AM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 12:49 PM
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 04:09 PM
12:50 AM
