Problem help - Mustang Evolution
Old 04-21-2015, 11:22 AM   #1
mustang_brody's Avatar
Problem help
Sometimes on startup when I put my car in reverse the car will die or act like it want to but when I drive it drives and idles perfect way could be the problem
mustang_brody is offline   Reply With Quote
Old 04-21-2015, 11:58 AM   #2
My first suspicion would be the Idle Air Control valve.
Old 04-21-2015, 02:10 PM   #3
How do u know when u have a bad idle air control valve
Old 04-21-2015, 06:42 PM   #4
One of the signs of a bad IAC is if you put your car in gear and it dies!
Does it only do it when you put it in reverse?
What about drive?
Just on cold starts? Or after it is warmed up, as well?
Old 04-21-2015, 07:06 PM   #5
In drive it don't but in reverse it does and both cold and warm but only every once and a while
Old 04-21-2015, 07:12 PM   #6
Intermittent problems can be difficult to diagnose.
How long has it been since the car has had a good servicing? Tune up, fuel filter, transmission service, etc.?
Old 04-21-2015, 09:03 PM   #7
It got new spark plugs about 5 months ago and my Cai filter was changed at that time also but everything else I haven't changed and I bought the car about a year and a half ago and it had 108k miles on it now it has 124k miles on it
Old 04-21-2015, 09:55 PM   #8
Ok. Well start doing the rest of the maintenance as you get the time and money.
1.Replace fuel filter
2. Change transmission fluid and filter.
3. Clean Throttle Body.
4. Clean Mass Air Flow sensor.
5. Change rear end gear oil.
Number 5 obviously couldn't cause your stalling problem but all of the rest of the items might, possibly, have an effect on the idle... Including the transmission.
And they are regular maintenance items anyways. This way, you can eliminate all of the simple things. Also, it never hurts to get the charging system checked out.
Old 04-21-2015, 10:00 PM   #9
Thanx good looking out
Old 04-25-2015, 05:52 PM   #10
Now the car keeps reving up and down to about 1000 rpms and if I don't keep my foot on the gas at a light it will die so it's the idle air control valve still right
Old 04-25-2015, 06:01 PM   #11
Yep.
Still sounds like the IAC.
Make sure to disconnect the battery when you change it.
Old 04-25-2015, 06:41 PM   #12
Ok thanx
Old 04-25-2015, 06:46 PM   #13
Ok thanx
Old 04-25-2015, 06:48 PM   #14
oxford5pointoh's Avatar
Make sure you get a good replacement part. I can't tell you how many times I have got a bunk part IAC from the autozones type stores
Old 04-25-2015, 07:01 PM   #15
Yes.
I highly recommend Motorcraft or a part manufactured by Hitachi.
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
i'm having a problem. need help. Black00GT 1996-2004 Mustang GT 4 06-17-2004 04:02 PM
possible IAC problem? HELP!? Horse Pre-2005 V6 Mustang 0 12-10-2003 12:59 PM
Plz help me fast!! Shift Kit problem 35thAniVertible Pre-2005 V6 Mustang 7 09-10-2003 10:58 PM
04:33 AM
