help please have video - Mustang Evolution
Old 04-22-2015, 05:43 AM   #1
2004 GT 5 Speed
ok it does it with the AC on the worst but will do it with it off what i start off in first and sometimes when just idle but over all mostly with AC on RPMs jump and some times car shuts off
Tazz6989 is offline   Reply With Quote
Old 04-22-2015, 07:25 AM   #2
fenixignition's Avatar
not able to watch the video at work, but look into IAC valve problems.
2002 GT 5sp. 16x,xxx miles
Old 04-22-2015, 09:00 AM   #3
Slater2111's Avatar
Kinda seems like a failing compressor for the ac.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 04-28-2015, 02:40 AM   #4
Anyone else have any ideas
---------- Post added at 08:40 AM ---------- Previous post was at 08:39 AM ----------
Anyone wale have any ideas
Old 04-28-2015, 04:22 AM   #5
Starting to do it now when just stopping at a stop sign not been using Ac at all could it have something to do with the cluth
Old 04-28-2015, 06:06 AM   #6
if you can, take another video so i can see whats going on with the clutch. i noticed the tensioner was moving as if it was given some throttle. it could be a bad tensioner, bad pulley elsewhere or a bad ac compressor and/or clutch. You may want to remove the belt, and spin each pully (aside from the crank of course) but make sure ac is off before you shut the car off, spin the compressor ( it should spin freely as long as the clutch is disengaged)
Old 04-28-2015, 06:08 AM   #7
ok ty for the input im off tomorrow and plan on relining my front bumper so ill take a look at that aswell
Old 04-28-2015, 06:23 AM   #8
ok i just went outside and let it run with ac on max all was good till the compressor kicked off then it stopped when it kicked back on
Old 04-28-2015, 06:32 AM   #9
So your saying it has a bad idle, a/c kicks in, clutch engages, is it pulling the rpms down and sometimes shutting off?
otherwise, if it runs fine with ac on, then stutters when ac disengages, it could have something to do with the IAC. the idle air control valve. When i turn on my A/C, the Iac will allow more air into the intake behind the throttle plate, raising my rpms a bit to make up for the ac being on.
so depending on exactly whats going on, it sounds possible that something is plugged up, and with ac on, it has a chance to get some extra air intake. if its the opposite, then when you turn on the ac, and it isnt getting that extra air, maybe its too much strain and shutting down.
Old 04-28-2015, 06:35 AM   #10
it idles fine till the ac clutch stops spinning then it starts to shake and rev high till the clutch starts spinning again
Old 04-28-2015, 06:39 AM   #11
ah. ok. then before assuming that it is the engine computer, or some other switch, I would double check on your freon level/pressure. when you run the ac, does it cut off on you and get warm?
I had issues with my ac before when it needed freon (small leak) and with too low of freon, at a stop sign or red light, it would cycle on and off, and i guess the computer got tired of my idle shifting from 700 to 1000 every so often, that it just decided to jump and hang at 1500 to 1700 on its own. I would check the freon, make sure its the right amount, and then unplug your battery, let it sit for 10 minutes, then recconect it and let it relearn the idle. first let it idle for a bit, maybe 10 minutes, then turn the ac on and let it idle like that for a few more, then take it out on the highway. once you drive maybe 5 to 10 miles i think, it should have relearned. worth a shot, and an easy first thing to try before diggin out parts.
Old 04-28-2015, 06:42 AM   #12
its ice cold and never gets warm
Old 04-28-2015, 06:53 AM   #13
dang. try the reset. see if that does it. if it doesnt, then it sounds like a vac leak or something plugged up maybe. hopefully if someone else had this happen and will recognize it and let us know how to fix it. hopefully not a computer related issue. those are the worst.
Old 04-28-2015, 06:55 AM   #14
well i put my dads odb 2 scanner on it and nothing shows up in the system
Old 04-30-2015, 11:24 AM   #15
Well after doing more research I took the IAC value off and cleaned it and it's running fine and no pro let stand so I'll be buying a new one soon and cleaning the whole throttle body
Old 04-30-2015, 11:33 AM   #16
I recommend a Motorcraft IAC or one manufactured by Hitachi.
Old 04-30-2015, 11:44 AM   #17
Yea that's what I've been told only motorcraft I can find is on rockauto
Old 04-30-2015, 11:49 AM   #18
There is a Rockauto discount code in the General Mustang forum.
The auto parts stores can usually order Motorcraft parts as well.
Old 04-30-2015, 11:51 AM   #19
Ok thinks a lot for the input
Old 04-30-2015, 12:07 PM   #20
Jbone007's Avatar
Yes sounds like it needs a good cleaning, may be a good time to get the whole fuel system checked and cleaned. I took my 2000 GT in and they cleaned the Injectors and TB and it ran much better! Had similar issue when coming to a stop!
Jbone007 is offline   Reply With Quote
Old 04-30-2015, 12:24 PM   #21
fomoco4life's Avatar
CCRM is a common a/c related fail in our vehicles
Old 04-30-2015, 12:27 PM   #22
Well I thought it was the Ac but it started doing it with the Ac off as well so I started looking into other problems
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 03:07 PM
Please help me! Please!! 98StangKid SVT Mustang 0 05-17-2013 09:40 PM
PLEASE, PLEASE HELP!!! Zoe 2005-2010 V6 Mustang 6 03-11-2012 01:19 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 08:46 AM
Sold a Car Please, please help!!? booth General Mustang Discussion 9 03-20-2010 09:29 AM
08:17 AM
