94 to 2004 K member Compatibility - Mustang Evolution
Old 04-23-2015, 11:21 AM   #1
Hello Everyone,
New to the Club
I Just picked up a 2001 bullitt with 59000 miles on it with some suspension damage on it.
No body damage.
It pushed the right front wheel back about an inch.
It took a hit on the right front lower control arm
And bent the K member.
I picked a good used K member from a 95 or 96.
The seller wasn't sure what year it came out of.
The K member has 4 holes the top (2 on each side of the towers}
The measurement from the 2 front holes center to center is 34 1/8.
The back holes center to center are 33 1/8.
Does anyone know if this used k member will fit in the 2001 4.6 bullitt.
I have been told that they are all the same.
And some people have told me it wont fit.
The 94 to 2004 K members look the same 6cyl and 8 cyl.
The only difference that See is a center hole on top of the towers on some of the later k members.(making that 6 holes on the top of the towers}
I didn't want to go with an aftermarket k member considering that they made 5600 bullits in 2001.
I wanted to keep it stock.
Thanks Tim
01 bullitt is offline   Reply With Quote
Old 04-23-2015, 12:01 PM   #2
The Bullitt K member is identical to all other 96-04 K members. If the guy was not sure whether it is a 95 or 96 then you need to figure it out because they are not compatible with each other. Plenty of pics on the interwebs.
Old 04-23-2015, 03:12 PM   #3
Steve96's Avatar
If it was a 95 I don't think it will be exactly the same. If It's a 96 then you should be OK. Or look into a UPR k member their reasonably priced and a pretty good piece.
1996 GT
Old 04-24-2015, 06:07 AM   #4
Thanks steve96
The used k member looks like its from a 96 from looking at other pics on the internet.
94 and 95 look Different from the used one that I have
if the pics have the correct year that they were from.
Old 04-24-2015, 06:10 AM   #5
Scotty I sent out a thanks for your reply yesterday on the post,
Didn't show up,,anyway if you didn't get thanks for the reply from yesterday
Old 04-24-2015, 06:47 AM   #6
Its all good. If you have a 96-04 V8 K member you are good, they are all the same. Just make sure it looks straight and that there is no damage to the front clip.
MSD CDI compatibility Panther140 General Mustang Discussion 0 03-08-2015 01:24 PM
13 gt500 front splitter compatibility Prezona 2011-2014 V6 Mustang 1 12-15-2014 02:40 PM
Compatibility between BBK 73mm increased throttle body & AIRAID POWERAID Spacer grom80 2011-2014 V6 Mustang 17 08-14-2014 11:22 AM
upgrade compatibility? pres_slappy Pre-2005 V6 Mustang 3 04-19-2006 01:26 AM
cam and computer compatibility 232SCstang Pre-2005 V6 Mustang 15 01-07-2004 02:52 PM
07:59 PM
