Rear end grind - Mustang Evolution
Old 04-23-2015, 08:49 PM   #1
Rear end grind
I've noticed sometimes I hear a faint grinding noise which I think is from the rear end. I can also feel it a little in the floorboard. It's so quiet it's hard to hear but when I can hear it it's at a slow speed with clutch in (~30mph) (exhaust makes it hard to hear so coasting is only time j hear it) it's like loud quiet loud quiet type sound like something's dragging unevenly. But like I said it's a dull grinding noise not really like metal to metal which would be high pitch I would think. Any ideas? Also my car is noticeably slower in the lower rpms like something is holding it back. Idk maybe it's the same problem? Thanks for any help
Sent from my iPod touch using Mustang Evolution
Calebnc302 is offline   Reply With Quote
Old 04-23-2015, 08:51 PM   #2
Also it's never gotten worse. Every time I notice it it's the same
Old 04-23-2015, 10:13 PM   #3
My car does the same thing while coasting, in gear, with the clutch disengaged. I notice it most when going through a fast-food drive-thru.
It doesn't seem to make any noise when coasting with the transmission in neutral.
I'm pretty sure that it is the transmission that is making the noise but I'm not too concerned about it because I don't often coast with the clutch depressed, and the transmission in gear.
Old 04-23-2015, 10:22 PM   #4
Mine does it outa gear too so maybe u joints or a bearing on the rear idk
---------- Post added at 12:22 AM ---------- Previous post was at 12:22 AM ----------
In*
Old 04-23-2015, 10:25 PM   #5
It does it both in and out of gear?
Whether the clutch is depressed or not?
Old 04-23-2015, 10:39 PM   #6
Region: Utah
mine is also doing the same thing. I am positive it is the bearing. it almost sounds like a plane lol. My friend that is a ford mechanic said its the bearings too. so i am going to replace them on sunday. I will keep you posted if the sound goes away. I just hope its not something else like the differential.
Mustang801 is offline   Reply With Quote
Old 04-24-2015, 01:06 AM   #7
Yea both in or out. Hardly ever brake dust in the back so it's gotta a beating or u joint, I changed oil in dif not long ago when it made a horrible racket while turning. That fixed that but this is a different noise/rumble/vibration idk it's s strange sound but speed related and very faint
Old 04-24-2015, 05:15 AM   #8
fenixignition's Avatar
which oil weight did you use?
2002 GT 5sp. 16x,xxx miles
Old 04-24-2015, 10:44 AM   #9
Whatever it said on the tag on the dif. I can't remember at the moment
Old 04-24-2015, 10:53 AM   #10
ok then 75-140 should be in there. otherwise, maybe add the friction modifier.
reason i asked was because a buddy of mine told me ford switched to thicker oil to quiet it down.
i have no idea if its true or not.
Old 04-24-2015, 12:25 PM   #11
In that case, you should put the rear end on jack stands and see if you can isolate the source of the noise.
When I bought my car, it had a bad axle bearing that produced a low rumbling noise that was most noticeable at lower speeds
Old 04-24-2015, 08:31 PM   #12
K thanks. I'll try that tmrw
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
reverse gear grind chris098 1996-2004 Mustang GT 8 01-21-2008 09:49 PM
clutch grind ChickStang02 1996-2004 Mustang GT 21 03-24-2007 05:20 AM
How hard to grind off powdercoating on MM sub frames? SpectorV Pre-2005 V6 Mustang 3 05-19-2005 05:20 PM
08:55 PM
