Turn Signals, Brake Lights, and Hazards are not working. - Mustang Evolution
Old 04-25-2015, 06:41 AM   #1
I have an 04 GT with 25,000 miles. The turn signals and brake lights stopped working all of the sudden a few weeks ago. I checked the fuses, 3 blew out. Numbers 13, 33, and 41. They are all 15 amp. I replaced them and tried the turn signals again, it worked for one click on the left side and blew the fuse again. I figured it was the multifunction switch because this is a common problem from what i understand. I installed the new switch, replaced the 3 fuses and tried the turn signals, brake lights, and hazards and non of them worked at all, but this time it didn't blow any fuses. I checked the connectors on the tail lights everything seems to be fine. I don't know what else to do other than to take it to a shop. Any suggestions?
Rusty_Surf90 is offline   Reply With Quote
Old 04-25-2015, 06:51 AM   #2
69mach1390's Avatar
It's the hazard switch went bad I had the same problem with a 03 mach 1. There all wired together
69mach1390 is offline   Reply With Quote
Old 04-25-2015, 06:55 AM   #3
isn't the hazard switch on the multifunction switch that i replaced?
Old 04-25-2015, 07:33 AM   #4
69mach1390's Avatar
Ok if u have replaced that. It could be the flasher relay
Old 04-25-2015, 07:41 AM   #5
Where is that located? I forgot to mention that i have a raxiom flasher modifier. I put the stock one back in to see if that worked but it didn't.
Old 04-25-2015, 05:51 PM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The flasher modifier is the relay he's talking about. I believe it's the one one near your right knee when sitting in the driver seat.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 04-26-2015, 03:39 PM   #7
Above your left knee is where the turn signal relay. When mine is not plugged in all the way, No turns, brake, and hazards.
-Happened 3 days ago.
Good luck
Wipers/Turn signals not working. Bford024 1979-1995 Mustang GT 2 03-12-2014 04:19 PM
flasher fuse blows and no brake lights/turn signals CCSOdeputy 1996-2004 Mustang GT 7 08-18-2013 12:11 PM
No hazards lights - ideas? 6805stang Classic Mustangs 12 09-30-2012 07:19 PM
Turn Signals Not Working irving91605 Pre-2005 V6 Mustang 18 06-15-2012 11:55 AM
Turn signals and breaklights not working Genocide 99gt 1996-2004 Mustang GT 10 01-30-2012 12:18 AM
12:25 PM
