Shaking clutch pedal until pedal is pushed - Mustang Evolution
Old 04-25-2015, 09:58 PM   #1
GHO5T5NIPER's Avatar
Just put new clutch, throwout bearing, pilot bearing, pressure plate in and now pedal vibrates until you put any pressure on the pedal and then is smooth and normal? I do have about an inch of dead travel in the pedal now also
Stock cable, exedy mach 400 clutch, ford racing pilot and throwout bearing
GHO5T5NIPER is offline   Reply With Quote
Old 04-25-2015, 10:05 PM   #2
Also when rpms climb the pedal vibrates faster. Not a bad vibration but can feel it in the pedal
Old 04-25-2015, 11:00 PM   #3
joe_117's Avatar
Mine does this! Just replaced what you did as well!
I would really like to know why it does this as well! It bothers the heck out of me.
joe_117 is offline   Reply With Quote
Old 04-25-2015, 11:04 PM   #4
Have you adjusted your cable all?
Old 04-25-2015, 11:22 PM   #5
Ok so took the dust cover off to look while the car was running and the clutch fork seemed like it was jumping around a lot. When pedal has pressure, it stops vibrating though.
Doesn't make sense. It never did that before the new clutch. Does it just need adjusted?
Old 04-26-2015, 10:15 AM   #6
So to adjust the stock cable you pull up on the clutch and you should hear a "zip line snap" and it should self adjust.
I did that and nothing happens... I got about an inch of dead travel
Old 04-26-2015, 11:04 AM   #7
joe_117's Avatar
Yea its adjusted. Im not so sure on it being from that tho.
If soccer sees this im sure he can state a few causes
Old 04-26-2015, 11:27 AM   #8
First of all, I recommend driving your cars as little as possible until you guys get this problem solved.
There are several things that can cause this but hopefully it is just that you guys don't have the TOB preload adjusted correctly.
Try pushing the clutch pedal all of the way to the floor, and then slowly release it, and then pull up FIRMLY. It should make a clicking noise. Then slowly press the pedal to the floorboards again.
If the factory quadrant is no longer able to properly adjust the clutch, you are going to have to get an aftermarket piece.
Scotty is the resident expert on this subject so hopefully he will see this and get you guys squared away.
Old 04-26-2015, 11:48 AM   #9
I did what you said about adjusting it and it's not doing anything
Old 04-26-2015, 11:55 AM   #10
Yeah. The one in my car doesn't seem to do anything either.
You will probably have to get an aftermarket quadrant and a firewall adjuster.
Old 04-26-2015, 12:02 PM   #11
Could slack in the cable be why it is vibrating? Once you push he pedal past the slack point the vibration in the pedal stops
Old 04-26-2015, 12:09 PM   #12
Yes it can!
When adjusted properly, the TOB should be just barely touching the fingers on the pressure plate.
Old 04-26-2015, 12:39 PM   #13
Yes it can!
My dad got under the car and looked through the dust cover with a mirror and he thought that a couple of the fingers on the pressure plate were always touching the tob. And when I pressed on the clutch, the rest of the fingers would touch and stop the vibrating.
But I do have an inch of slack that I didn't have until after the new clutch was put in
Old 04-26-2015, 12:48 PM   #14
What brand throw out bearing did you install?
aero86 is offline   Reply With Quote
Old 04-26-2015, 12:55 PM   #15
All of the fingers should be level and all of them should be in slight contact with the throw out bearing.
What brand is the pressure plate?
Old 04-26-2015, 01:00 PM   #16
Exedy pressure plate and mach 400 clutch, ford racing throwout and pilot bearing. I took a couple good videos but idk how to post them on here or if you can
Old 04-26-2015, 01:05 PM   #17
Hmmm.
Could any of the fingers have gotten bent during the transmission install?
You have to post the video on YouTube and then post a link on here.
Old 04-26-2015, 01:10 PM   #18
Video through the dust cover. Some of the fingers on the pressure plate touching the throwout bearing before the others. Thinking this is what's causing the vibration in the pedal. What do you think? This is pushing he clutch pedal through it's slack point
http://youtu.be/EqGP0O_Zppk
May have to open video in safari to see it.
Old 04-26-2015, 01:15 PM   #19
The video is private.
That will cause the vibration!
Old 04-26-2015, 01:19 PM   #20
How about now?
Old 04-26-2015, 01:30 PM   #21
That worked.
I can see that one finger that sticks up.
They should all be at the same height.
Old 04-26-2015, 01:38 PM   #22
This is a McLeod but the fingers should look like this.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 04-26-2015, 01:42 PM   #23
Yeah I guess I should've payed closer attention to that before I put it in, but it's too late for that now. Going to have to take ****ing thing apart again for a new pressure plate.... Fml.... I am beyond pissed right now
Old 04-26-2015, 07:05 PM   #24
I'm looking for just the mach 400 pressure plate with no clutch and I can't find it anywhere any ideas?
Old 04-26-2015, 10:29 PM   #25
This company may have them.
http://www.rpmware.com/catalog/group/50512
Old 04-26-2015, 10:42 PM   #26
Thanks for the research. It looks like you have to be ordering trough a company to register on their website
Old 04-26-2015, 10:46 PM   #27
I just Googled "Exedy Pressure Plate repair".
There must be a source for just the PP.
Maybe Exedy themselves...
Old 04-26-2015, 11:07 PM   #28
Yeah I'm gonna ca them in the morning and see what they can do. May end up just having to buy another kit and have them reimburse me
Old 04-27-2015, 04:19 PM   #29
Got transmission dropped again but from looking at the pressure plate I can't see that the fingers are bent. But in that video I took, your looks pretty obvious some fingers are always hitting the throwout bearingClick image for larger version
Name:	ImageUploadedByMustang Evolution1430173156.180039.jpg
Old 04-27-2015, 04:38 PM   #30
It might be an optical illusion but all of the fingers look off center to me.
Did you torque the PP down correctly?
Old 04-27-2015, 04:50 PM   #31
Yes I can't remember exactly what I torqued to, I think 55 ftlb rings a bell. And I think I torqued flywheel to 80-85
Old 04-27-2015, 04:55 PM   #32
And in a diagonal pattern I presume.
Am I correct that the pressure plate fingers looks off center? Or did the clutch disc move?
And what the hell were we looking at in that video?
Old 04-27-2015, 05:21 PM   #33
I think it just looks that way from the angle. Everything bolted in fine anyway. And the video was looking through the dust cover at the throwout bearing and the pressure plate
Old 04-27-2015, 05:28 PM   #34
Yes. But what was that finger that was circled?
Old 04-27-2015, 05:39 PM   #35
That is the finger that looked like it was always impacting the throwout bearing before the others were. I'm thinking that is why the pedal would sit there and vibrate when the clutch wasn't depressed and would stop and be smooth when the rest of the fingers hit the tob when you depressed the clutch a little bit
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
HELP, 2010 GT Shaking When I Let Out Clutch Mgalli 2011-2014 Mustang GT 2 02-11-2015 01:09 PM
03 GT stalls out when clutch is pushed in Clingman92 1996-2004 Mustang GT 2 10-01-2013 12:52 PM
Strange noise and clutch pedal shaking? rachaellee Pre-2005 V6 Mustang 5 10-24-2012 01:37 AM
Manual window goes down when its pushed, what part does it need? Bearach General Mustang Discussion 3 03-21-2010 02:13 AM
» Members Mustangs
Bella
sixpac
Sally
Destro415
Add your Mustang
12:53 AM
