What to do next? - Mustang Evolution
Old 04-26-2015, 09:31 PM   #1
keeney35's Avatar
What to do next?
After this weekend, my 04 GT will have a cold air intake, 73mm throttle body/plenum, underdrive pullies, stage 3 cams, 47 lb injectors, msd ignition, longtubes, off road h, no cats, egr delete, new valve springs and retainers, adjustable cam and crank gears, upgraded fuel pump, front and rear strut bars, lowered 1.5", subframe bars, front and rear anti roll bars, steeda short throw shifter and stage 3 clutch, caster/camber plates, and 3.73 gears..
It will be dyno tuned afterwards... So first what's a rough estimate as far as hp and tq? And what can be my next mods? I really want to Goto a f-1 procharger, also I have a 150 shot but it won't get used very much
keeney35 is offline   Reply With Quote
Old 04-27-2015, 12:13 PM   #2
325 hp!
You have the bolt-ons pretty much covered except for rear lower control arms and under drive pulleys.
If you want to go FI, I suppose that you should start thinking about the supporting fuel system mods...
Old 04-27-2015, 12:28 PM   #3
Rapinator126's Avatar
If you are planning on a F1 head unit. You better build the bottom end, bc the F1 will be a waste on a stock motor. Also better be looking at something more than 47lb injectors.
And stage 3 NA cams will be a waste in a supercharged motor.
Honestly you need to rethink your build from step 1 if this is your goal
Old 04-27-2015, 12:31 PM   #4
keeney35's Avatar
I've got the pullies, and have an upgraded pump and injectors..
So I was thinking some weight reduction stuff, tubular k member, lighter driveshaft, the control arms, lighter racing seats, fiberglass hood.. Then of course some FI next tax return..
Right now all I have is the pullies, cold air, throttle body/plenum, short throw, stage 3 clutch, o/r H and exhaust, 3.73 gears, lowered 1.5" and the strut bars..
So will I notice a big difference with the tune and new parts? (Headers, cams, fuel goodies and subframe connectors, dyno tune)
Old 04-27-2015, 12:33 PM   #5
1. Just a pump and injectors won't be good for a F1 head unit build. You will need a full return style sytem.
Old 04-27-2015, 12:33 PM   #6
keeney35's Avatar
Well I mean I don't have to have the f-1.. I just don't wanna spray.. I might be happy with what I have.. But is this all I can do as far as power without going f/i
Old 04-27-2015, 12:42 PM   #7
Haha.
I read your first post like 5 times looking for pulleys!
Yes! Aside from building the motor and raising the compression ratio, you have done everything for NA.
What are your goals for the car? Road race or drag race?
Old 04-27-2015, 12:43 PM   #8
Except maybe ported PI heads or TFS heads...
Old 04-27-2015, 12:46 PM   #9
keeney35's Avatar
I was looking at tfs heads, but I think I will tell a big difference from the hp I'm at now which is probably 265 maybe... But it's my daily driver lol I take it to the strip every once in awhile
Old 04-27-2015, 12:52 PM   #10
That will be a fun engine and you will definitely notice a difference!
Old 04-27-2015, 12:55 PM   #11
keeney35's Avatar
Bone stock is 240 at the wheels correct? So with the pullies, throttle body/plenum, o/r H ,exhaust and cold air in probably 265 now right?
So if he can squeeze 325-330 out of it with the 91 tune I think that would be a huge difference
Old 04-27-2015, 12:58 PM   #12
Different dynos will show different numbers but you are right in the ballpark.
Old 04-27-2015, 01:01 PM   #13
keeney35's Avatar
Now if I want to throw my 150 shot on there, will j need different cams? Or just build the bottom end?
Old 04-27-2015, 01:06 PM   #14
This is Rapinator's field of expertise but the setup that you have should work very well with nitrous. With a 150 shot you will be right around the limits of what the stock rotating assembly can handle, as far as horsepower.
Old 04-27-2015, 01:29 PM   #15
keeney35's Avatar
I'll probably get forged internals and build the bottom end, crank Pistons rods and such just because I don't wanna blow up my daily lol
Old 04-27-2015, 01:37 PM   #16
Forge it and do the heads and cams then spray it. Plate kit 200 shot.
---------- Post added at 01:37 PM ---------- Previous post was at 01:37 PM ----------
A NA cam will work perfectly for nitrous
Old 04-27-2015, 02:27 PM   #17
keeney35's Avatar
Would the edelbrock intake manifold add anything?
Old 04-27-2015, 02:31 PM   #18
It will add some horsepower at high RPM's but you will lose a LOT at lower RPM's.
They aren't good for daily drivers...
Old 04-27-2015, 02:40 PM   #19
keeney35's Avatar
I like my lows lol so spray away, I'm looking for the forged internals now and some lower end parts so is MMR the place to look
Old 04-27-2015, 02:41 PM   #20
They are good.
Livernoismotosports also
Lethal performance
Old 04-28-2015, 07:56 AM   #21
Guessing 295 rwhp currently. What exact cams are you getting? Like actual part number. "Stage" is just a marketing term. My guess is comp 270s.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 04-28-2015, 08:39 AM   #22
keeney35's Avatar
Yes comp 270
Truck will be forsale next spring. What to get next? sonic04edge The Bar 28 09-26-2006 07:45 PM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 07:03 AM
So, I'm going to a rave next weekend... .:DarkEntity:. The Bar 3 09-13-2003 11:37 PM
What should I get next dapack69 Pre-2005 V6 Mustang 11 08-19-2003 08:20 AM
HELP, NEED TO KNOW WHAT TO DO NEXT mheath Pre-2005 V6 Mustang 6 07-27-2003 04:01 PM
01:09 PM
