Intermitent stalling at idle? - Mustang Evolution
Old 04-27-2015, 01:46 PM   #1
2001 Bullitt 4.6
Car runs fine most of the time,Sometimes at idle
it makes a sound like a foghorn( like the air is getting restricted}Then dies,,,
If I here this sound starting I throw a few revs it goes away and doesn't stall.
Any Ideas???
Thanks Tim
01 bullitt is offline   Reply With Quote
Old 04-27-2015, 05:49 PM   #2
fenixignition's Avatar
Lift the hood and watch your vac lines. One may be collapsing
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 04-27-2015, 05:58 PM   #3
This is simple.
Your Idle Air Control valve is worn out and the plunger inside is vibrating and making that noise.
I recommend replacing the IAC with a new Motorcraft part, or one manufactured by Hitachi.
Before you begin replacing it, disconnect the battery. That way when you are finished, you can reconnect the battery and the computer will relearn the new idle trim.
Old 04-27-2015, 06:13 PM   #4
Foghorn noise though? I thought they squeal? Either way your probly right.
Old 04-27-2015, 06:26 PM   #5
One of our members (cliffyk) used to refer to it as a "French horn" sound.
My car was doing the same thing as OP's car... Replacing the IAC did the trick!
Surging Idle, stalling, and fuel pump Alex5123 1979-1995 Mustang GT 4 09-01-2014 07:13 AM
intermitent grinding/scraping noise victormastro556 2011-2014 Mustang GT 6 04-03-2014 09:12 AM
95 gt cold start, stalling at idle issues.. need help BloodRedStang 1979-1995 Mustang GT 3 09-02-2013 09:31 AM
Stalling/rough idle after start up? brianw64 2011-2014 Mustang GT 11 12-18-2012 07:53 PM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
07:12 AM
