Bank 1 plugs darker than bank 2. No codes - Mustang Evolution
Old 04-30-2015, 12:23 PM   #1
03 gt btw. Not by a ton but bank 1 has noticeably darker s plugs. Pretty clean, but a couple shades darker. Every now and then my idle will be a tad random, like when coming to a stop usually hangs at 1100 until I stop sometimes it's 1400 others it drops to idle before I even stop but always rests at ~800 and smooth. Sometimes when not fully warmed up at low rpms in any gear when giving it a little more gas it will kinda lurch a little if ur looking for it. But nothing bad it's a very smooth running car. Some times it randomly pulls a lot harder at wot than usual and seems like half or 3/4 pulls just as hard sometimes.
Pulled codes there are none. Things I've done: brand new ford maf, rebuilt injectors, clean kn filter, clean iac, clean tb and plenum, gapped plugs, new fuel filter, changed oil.
Car is stock except kn filter, super 40s and or x pipe with mil elim. Has 170xxx on her but previous owner garage kept it and drove hwy mostly. One of the cleanest stangs with that mileage. If there are no codes and fuel trims and all look good (dad data logged it at work for me) I'm out of ideas. Maybe a small exhaust leak or weak O2? Thought they would cause a code but who knows. Maybe cam timing? Doubt it but any ideas guys? Maybe nothing at all?
Sent from my iPod touch using Mustang Evolution
Calebnc302 is offline   Reply With Quote
Old 04-30-2015, 02:45 PM   #2
My 02 gt does the little lurch thing when not fully warmed too..so I would definitely be interested to hear ideas also. Mine has 95000 miles, super 10 mufflers and a cai, so pretty much stock.
Vinnie02 is offline   Reply With Quote
Old 04-30-2015, 03:19 PM   #3
Well you are starting to narrow it down!
I'm thinking that the bank 1 oxygen sensor is getting weak...
Old 04-30-2015, 07:12 PM   #4
Yea I might replace the upstream o2s in near future... Any of you geniuses on this forum feel free to add your inputšŸ˜¬
Old 04-30-2015, 07:18 PM   #5
Also ntk sensors are about the best correct?
Old 04-30-2015, 07:22 PM   #6
I only use Motorcraft or Bosch for the O2's...
Old 04-30-2015, 09:54 PM   #7
I'll try and order some nxt week hopefully that'l help something. Couldn't hurt
Old 05-01-2015, 05:13 AM   #8
fenixignition's Avatar
NTK are the oem.
But i take it the bosch work good for you without any issues?
2002 GT 5sp. 16x,xxx miles
Old 05-01-2015, 09:56 AM   #9
Originally Posted by fenixignition View Post
NTK are the oem.
Bosch invented Oxygen sensor technology. I have never had an issue.
I like to use Motorcraft, or whoever Motorcraft is using to manufacture their 02 sensors.
I leave that choice up to them.
Old 05-01-2015, 10:46 AM   #10
Ordered some motorcraft from summit for $41 per. They are on back order so it'll be a couple weeks but I figured motorcraft would be about the best
Old 05-01-2015, 10:48 AM   #11
The reason being, I read that aftermarket Bosch and ntk specs are different then the ones they made for ford. I just wanted something as close to factory as possible and I think motorcraft is the way to go
Old 05-01-2015, 10:51 AM   #12
This will be interesting to see if it helps!
Make sure that you disconnect the battery while you are replacing them. That way the computer can relearn the new A/F ratio.
Old 05-01-2015, 11:11 AM   #13
I will post results for sure. And yes that is a must lol
Too lean bank 1 and bank 2 meno1994 2011-2014 Mustang GT 33 02-06-2015 11:50 AM
Bank 1 and bank 2 running lean. Rich04 1996-2004 Mustang GT 19 04-23-2013 07:20 PM
Smokes on the drivers side alot more than than the passenger side Drgula5 1979-1995 Mustang GT 4 09-15-2012 12:08 PM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
darker taillights/ tints DonnyM32 Pre-2005 V6 Mustang 3 07-19-2006 09:55 PM
07:22 AM
