What to torque exedy mach 400 pressure plate - Mustang Evolution
Old 05-02-2015, 11:14 AM   #1
GHO5T5NIPER's Avatar
Hey Just want to double check what do I torque the stock flywheel and mach 400 pressure plate to?
GHO5T5NIPER is offline   Reply With Quote
Old 05-02-2015, 12:55 PM   #2
Torque the flywheel to 59-64 ft-lbs.
Pressure Plate to 12-22 ft-lbs.
straybullitt is online now   Reply With Quote
Old 05-02-2015, 04:27 PM   #3
That doesn't seen very tight at all
Old 05-02-2015, 06:33 PM   #4
So I'm assuming 55 on the pressure plate is way too much....?
Old 05-02-2015, 06:55 PM   #5
Those are the factory torque specs.
Old 05-02-2015, 06:55 PM   #6
Old 05-02-2015, 09:55 PM   #7
I torqued the flywheel to 85 and pressure plate to 55 as I read on another forum.. Think the bolts are ruined because of being over torqued?
Old 05-02-2015, 10:00 PM   #8
Old 05-02-2015, 10:25 PM   #9
I'm not completely sure.
Those torque specifications that I quoted are from a repair manual. I trust that more than the internet...
I couldn't find any torque specifications in Exedy's instructions, so I assume that you are supposed to use the factory specs.
I have inadvertently over-torqued bolts, in the past and haven't had any problems, but i have always looked up the important torque specifications in the manual ... Such as flywheel bolt and head bolts, things like that.
Old 05-02-2015, 10:28 PM   #10
Here's exedys page. Same thing you said. My own fault for trusting the internet and some camaro guy trolling...
http://www.exedyusa.com/multimedia/s...queRatings.pdf
Old 05-02-2015, 10:35 PM   #11
Is the transmission installed yet?
Old 05-02-2015, 10:36 PM   #12
Was. Had everything out in a little over an hour. New world record? I'm getting good at this **** lol just make too many dumb mistakes lol
Old 05-02-2015, 10:39 PM   #13
Lol.
You are getting faster than Scotty!
You must have a transmission jack?
Old 05-02-2015, 10:43 PM   #14
So I just looked up the torque specs for my F250 and the flywheel torque is about the same as what you torqued yours to...75-85 ft lbs.
Old 05-02-2015, 10:48 PM   #15
And the pressure plate is 15-30 ft-lbs...
The PP definitely got over-torqued.
Old 05-03-2015, 12:19 AM   #16
Took flywheel and pressure plate off and cleaned, retorqued them again. For some reason they seemed to be all around 40 pounds not 55 so that's a bit better. Staying up late tonight and throwing everything back in. Crossing fingers it'll be ready for a car show tomorrow afternoon
Installed Exedy Mach 500 Clutch & Lightweight Flywheel Deerslayer 2011-2014 Mustang GT 33 05-08-2017 09:44 PM
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
Exedy mach 400 stage 2 Kstangs2002 1996-2004 Mustang GT 6 03-26-2013 10:41 PM
Exedy Mach 350 Stage 1 Clutch TopgearGT 1996-2004 Mustang GT 3 06-07-2012 11:40 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
01:36 AM
