Now, onto all the "issues" I have found with the car. Obviously besides the blown motor:
1- Pile of **** Flowtech X pipe. This pipe was the first pipe I ever bought when I got into mustangs before I knew any better. It goes BELOW the front of the trans not only getting things hot as **** but ground clearance problems... Will be getting replaced probably with a UPR stainless X. Yeah it is corroded, the rest of the underside of the car is mint as is the Bassanni catback.
2- God effing dammit DIY non-full length subframes. Again, no biggie and actually saves me from going out to get full lengths for a little while. I can remove these easy enough with the car on a lift and a grinder.
3- The seller told me this was the "SCT Tuner". Lol. Well that wire looks like a wire to a piggyback chip which I will have to dig into. Controller is to the snow meth kit which I will be removing and selling.
4-Top of the track on the triangle area of the door is broken. Window comes up real far and you have to stop it manually at a certain spot. Glass rattles if it is down when I close the door. Will have to pull the door panel and see wth. Also will have to replace that piece when I get around to it.
5-Only real "blemish" I can find in the interior that isn't like a missing clip or something. Not really going to worry about it. Maybe if I get some SEM interior dye or something I will go over it...
6-Wheels are going to need blasted/coated. Now that I don't have to immediately do subframes, I will take that $400 and have that done instead or I might just leave it... Does need new tires soon, it has 285/35/18 Nitto 555s on all 4 corners. I imagine this car will handle very well even though the 4 link is still in place...
There is a little surface crud on the OEM A arms and a little road crud on some other parts of the car but it is cleaner than my 98 and that was CLEAN. There is zero rust around the gas tank on this car like my 98 had and the interior is not quite the 10/10 the seller said but its a solid 9 easy.
Paint... is VERY good. Has the peeling by the hood/fender gap that they all get and a little flaking where it looks like one of the big Bassanni tailpipes was touching but besides that it is going to shine up like a gem.
Engine bay... this thing is CLEAN. Looks like a showroom new engine bay TBTH.
Overall, very happy with this purchase. I can get a Vic motor for $500 with 30-40k on it which is the route I am going. Will look for a 3V "aluminator" block down the road to start a build with.
Let me know if you guys think of anything else.
