Low compression - Mustang Evolution
Old 05-03-2015, 11:50 PM   #1
Low compression
I have a 2000 mustang gt ,I bought some pi heads and mild cams . I had it sent out to a machine shop to get some work done had it installed and it had a code for random misfire that wouldn't go away. I did a compression test and in cylinders 5-8
It had 100-110 on 1-4 I had 170 all across and it's running really rich . Anyone know what it could be ?
yahua2233 is offline   Reply With Quote
Old 05-04-2015, 12:14 PM   #2
Did you do a "by the book", accurate, compression test?
Can you go into a little more detail as to the work that you had done and any codes that you have?
Old 05-09-2015, 12:56 PM   #3
ultrawhiteSN95's Avatar
Any cylinder below 90 psi is bad , means your engine is more than likely gone , 100 psi is fairly normal but anything over 100 psi means your engine is ok
1998 GT, Edelbrock Victor Jr. Ford 4.6L SOHC, Edelbrock Fuel Rails, 1999 Gt Engine w/ PI Heads,Accufab 70mm TB & Plenum,Fuel Pressure Regulator 515 Series Inline Return Style, 25-90 psi, Underdrive Pulleys,MSD ignition coils ,4.10 gears,Diablo Sport Predator Tuner
ultrawhiteSN95 is offline   Reply With Quote
Old 05-10-2015, 02:47 PM   #4
CandymanGT's Avatar
Low compression
Sounds like they didn't deck 5-8 or something... That's assuming of course you had it done.
CandymanGT is offline   Reply With Quote
low compression mike92691 Classic Mustangs 17 12-22-2010 10:00 AM
Looking for a set of low low ratio 7.5" gears PureVenom Pre-2005 V6 Mustang 4 08-13-2008 05:15 PM
03 Gt Pi Heads And Cams!!!! Low Miles/low Price alwaysthefinest Mustang Parts for Sale and Wanted 1 05-24-2007 06:17 PM
how low is too low? Kyle Mustang Audio & Video 41 01-25-2007 09:53 PM
Low Compression from Cylinder #2 robert0803 Pre-2005 V6 Mustang 14 04-08-2005 09:44 PM
05:55 AM
