Service engine soon light - Mustang Evolution
Old 05-04-2015, 11:42 AM   #1
So my service engine light came on today while on a short ride. No lagging, spitting or any other noticeable issue. She is running and idling like a top. Any ideas? Not too keen to bring her into the shop if I don't have to.
Vinnie02 is offline   Reply With Quote
Old 05-04-2015, 11:45 AM   #2
natestang07's Avatar
Take it by AutoZone and get codes ran
Old 05-04-2015, 11:55 AM   #3
I didn't know that they did that....thanks for the info.
Old 05-04-2015, 12:29 PM   #4
Dub9stang's Avatar
Yea they will print out a code along with the top causes for the code. If you got no drivability issues hopefully its something as simple as a loose fuel cap
Dub9stang is offline   Reply With Quote
Old 05-04-2015, 12:51 PM   #5
keeney35's Avatar
I drive with mine on constantly for having no cats, but hopefully it's just something simple like a sensor
keeney35 is offline   Reply With Quote
Old 05-05-2015, 07:47 AM   #6
Went to advance auto to have the code read and it said O2 sensor 1 bank 2 lean condition. Then they cleared the code. So I will have to take care of that at a later time. Is that the sensor before or after the cats?
Old 05-05-2015, 12:32 PM   #7
boostedhog88's Avatar
Region: Arkansas
Driver's side behind the cat.
"My car is too fast" - No car guy ever
boostedhog88 is offline   Reply With Quote
Old 05-05-2015, 12:58 PM   #8
Thanks boosted.
Old 05-05-2015, 03:12 PM   #9
Slater2111's Avatar
Im pretty sure he means drivers side pre cat oxygen sensor. Just to clear that up
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 05-05-2015, 04:47 PM   #10
Region: Arkansas
Yeah I did, thats what i get for being on the forum during work
Old 05-07-2015, 07:08 PM   #11
fenixignition's Avatar
yep. bank 1 is the side with cylinder 1, in our case, drivers side. sensor 2 is the second sensor down the line. post cat. also called downstream. upstream being sensor 1, pre cat.
2002 GT 5sp. 16x,xxx miles
Old 05-09-2015, 06:11 PM   #12
Light came back on...but I already know its the o2 sensor. But it's reading a lean condition, does that mean I am having an injector problem?
Old 05-18-2015, 07:03 AM   #13
Figured out the issue...cai was loose after the MAF sensor. Will the code reset itself or do I have to have it cleared.
Old 05-18-2015, 07:04 AM   #14
I would get it cleared. But it may go away on its own after a certain number of miles.
Actually, I would do a battery pull so the ECU can relearn its idle and such, since it was an opening in the intake tubing.
Old 05-19-2015, 06:15 PM   #15
Panther140's Avatar
You probably know my take on this **** haha
Panther140 is offline   Reply With Quote
Service Engine Soon light on WhiteStang99 Pre-2005 V6 Mustang 20 07-22-2015 08:42 PM
The Service Engine Light Soon light is on!! HELP! punisher0822 1996-2004 Mustang GT 11 07-15-2010 10:15 PM
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
service engine soon light (ugh) johnww Pre-2005 V6 Mustang 9 03-17-2005 05:39 PM
service engine soon light tek55 Pre-2005 V6 Mustang 4 11-13-2003 02:00 PM
09:38 PM
