O4 gt misfire - Mustang Evolution
Old 05-04-2015, 06:44 PM   #1
O4 gt misfire
just bought a 04 gt three days ago and it's popping a cylinder 4 misfire and random misfire code. The shop has checked coils, compression, plugs ect and can't figure it out. Thinks it has something to do with the injector. I have bigger injectors, better coils, not sure what else because I bought it that way. Anyone have a similar problem? Should I just go back to oe injectors? Thank you.
Chisholm23 is offline   Reply With Quote
Old 05-04-2015, 07:08 PM   #2
Do you know if the car has a tune?
What color are the injectors that are on the engine right now?
If you want to check for a bad fuel injector, remove the one from the misfiring cylinder and swap it with the cylinder next to it. Then clear the codes and see if the misfire code moves to cylinder #3.
Old 05-04-2015, 07:51 PM   #3
I don't know if it's had a tune. Bought it from a dealership and they don't know. Also I hadn't looked at the injectors. The shop told me today that's what they think it is. When I pick it up later I'll reply again.
Old 05-04-2015, 09:42 PM   #4
So I'm an idiot. The dealership lied to me, it's the pink stock injectors.
Old 05-04-2015, 09:52 PM   #5
You can try moving that injector to another cylinder and see if the misfire code follows it.
If the coil and the spark plug and the fuel injector all check out good, the next thing to do will be a compression test.
Another misfire 2000MustangGT17 1996-2004 Mustang GT 5 06-24-2009 08:47 AM
#1 misfire 2kslvrgt 1996-2004 Mustang GT 4 02-17-2009 01:26 PM
another misfire! Jeremym831 1996-2004 Mustang GT 4 03-03-2008 10:01 AM
misfire in #1 vramos1 Pre-2005 V6 Mustang 4 09-15-2007 02:24 PM
Engine runs, but hesitate/misfire jaynez31 Pre-2005 V6 Mustang 11 01-17-2006 05:30 PM
10:25 AM
