Rear brake caliper problems. - Mustang Evolution
Old 05-05-2015, 12:28 PM   #1
Speed_Mister's Avatar
Region: Arkansas
I put new rotors and had to get a new caliper because my old one was locked up and over extended. I installed the new one, tightened the brake lines on caliper and hooked e-brake cable to it. We bleed the brake but the caliper will not compress. What's going on?
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 05-05-2015, 12:46 PM   #2
natestang07's Avatar
If it is anything like mine you have to twist it while compressing. Can't do the normal c clamp it in thing
Old 05-05-2015, 12:50 PM   #3
Region: Arkansas
It will slide on the rotors and brakes. It's the piston in the caliper won't compress on the brakes...
Full Bolt Ons
370rwhp 470rwtq
Old 05-05-2015, 01:02 PM   #4
Yes on mine to compress the piston in you have to twist and compress at the same time.
Old 05-05-2015, 01:03 PM   #5
https://youtu.be/m5MxG1m7X5U
Skip towards the middle
Old 05-05-2015, 01:24 PM   #6
Lol, his original caliper was probably fine.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 05-05-2015, 01:27 PM   #7
I was lucky and looked it up before I did mine. I would have busted the piston just shoving it in there lol
Old 05-05-2015, 02:16 PM   #8
Region: Arkansas
Look my problem isn't getting the caliper back on the rotor. My problem is my caliper is loose on the rotor and I have no pressure on the brake pedal. We bleed that brake lines for about 30 minutes and still no pressure.
Full Bolt Ons
370rwhp 470rwtq
Old 05-05-2015, 02:33 PM   #9
So the piston is compressed and won't come back out is what you are saying? Not sure about that never dealt with it. Only thing I would say is just try to keepbleeding them until you get pressure.
Old 05-05-2015, 06:29 PM   #10
WJL
Open the bleeder screw and leave it open (shouldn't take that long) it will fill itself. Once its dripping out the bleeder close, refill the master, pump brakes and bleed, in fact bleed both side rears. See if that makes a difference.
WJL is offline   Reply With Quote
Old 05-05-2015, 07:44 PM   #11
Region: Arkansas
I finally got it somewhat to compress. But the brake petal hardly feels like there's anything there. Got it good enough to drive it out of my buddy's shop. I'm gonna need to do a bleed my brakes day sometime. What's the procedure of doing a correct bleeding job. Isn't it like master cylinder first, then RR, FR, RL, and FL?
Full Bolt Ons
370rwhp 470rwtq
Old 05-05-2015, 07:55 PM   #12
If you haven't bled them yet that's probably your entire issue especially replacing the caliper.
The 2 person bleed will work (google it) but I just bought a pressure bleeder. Crank it up to 15 psi to get past the ABS controller and crack the rear right caliper till it runs clean, check pressure, then left rear, then front right then front left. This ensures there is absolutely zero air in the system vs the 2 person method which is not 100%.
Old 05-05-2015, 07:58 PM   #13
He said earlier he bled it
Old 05-05-2015, 08:16 PM   #14
Yeah but then he is asking how to bleed... I dunno. I just use my power bleeder and don't have to hear the wife ***** about sitting in a hot car pumping the brake pedal lol.
Old 05-12-2015, 03:02 PM   #15
fomoco4life's Avatar
Lmao, mine complains every time
fomoco4life is online now   Reply With Quote
Rear Brake Caliper Compression gweze001 Mustang DIY and Technical 0 02-16-2015 09:00 AM
Rear Brake Caliper Issue jaymjohnson 2005-2010 Mustang GT 12 11-05-2012 10:33 PM
brake caliper paint question bluestang1724 Pre-2005 V6 Mustang 11 03-23-2011 11:53 AM
Rear brake caliper anchor bolt size/help CakeOrDeath? Pre-2005 V6 Mustang 5 09-01-2007 12:04 AM
Brake Caliper Paint? FloMasta24 Mustang Audio & Video 21 09-12-2004 04:06 PM
03:52 AM
