Help please - Mustang Evolution
Old 05-07-2015, 08:38 PM   #1
code_cobra911's Avatar
Help please
So I completed the 5.4 2v swap into my v6 and now I'm havin a little bit of a problem. I've lost a major amount of power. My motor seems like it's straining a bit and I keep having this loud bang under my car whenever I shift under high rpms. Also whenever I crank it something squeaks loud for like a second. It sounds like a bad belt squeak but it's not it's more under the car
code_cobra911 is offline   Reply With Quote
Old 05-07-2015, 08:40 PM   #2
Also it's vibrating really bad when cruising
Old 05-07-2015, 08:42 PM   #3
natestang07's Avatar
Is your clutch toast?
Old 05-07-2015, 08:43 PM   #4
No clutch is good it's brand new and I'm having no trouble with it
Old 05-07-2015, 08:45 PM   #5
So what all did you swap into the car?
Old 05-07-2015, 08:46 PM   #6
Motor stated, t-45 tranny, gt driveshaft, and a 7.5" rear end with welded spider gears. Not the best idea but I don't think that's the problem
Old 05-07-2015, 08:48 PM   #7
So I'm going to focus mostly on the power part of the issue since that is what I have a little knowledge on. What was the 5.4 out of?
Old 05-07-2015, 08:48 PM   #8
An 01 expedition 4x4
Old 05-07-2015, 08:49 PM   #9
Did you swap cams, intake and heads? And how high are you revving it?
Old 05-07-2015, 08:51 PM   #10
Intake was swapped to a van intake same year just for bigger runners. Cams are the same so are the heads.
Old 05-07-2015, 08:51 PM   #11
You might be over revving the cams/ intake
---------- Post added at 07:51 PM ---------- Previous post was at 07:51 PM ----------
And it will feel sluggish until those get swapped
Old 05-07-2015, 08:53 PM   #12
The highest I shift at is around 5100 rpm and I have a tune on it too to extend the rev limiter
Old 05-07-2015, 08:54 PM   #13
You can extend the limiter all you want but at the end of the day those cams and that intake are not built for it. I wouldn't rev that high until they are swapped.
Old 05-07-2015, 08:55 PM   #14
It does it even when cruising so could that still be it? Or could it be something with the drivetrain?
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 03:07 PM
Please help me! Please!! 98StangKid SVT Mustang 0 05-17-2013 09:40 PM
PLEASE, PLEASE HELP!!! Zoe 2005-2010 V6 Mustang 6 03-11-2012 01:19 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 08:46 AM
Sold a Car Please, please help!!? booth General Mustang Discussion 9 03-20-2010 09:29 AM
03:42 PM
