Late start issue - Mustang Evolution
Old 05-11-2015, 04:42 PM   #1
robin_gt's Avatar
Late start issue
hi folks,
so just now i tried starting the car and it just cranked for like 3 seconds without starting, after that i tried again with throttle half way down cranked again without starting then i tried again and it finally started after like 2 seconds of cranking, it's quite annoying.
what are some things that could cause this?
the car has 145k miles and i changed plugs like 8k miles ago and i changed the fuel filter around 7k miles ago, cleaned the maf 1k miles ago, no check engine light
Thanks alot
robin_gt is offline   Reply With Quote
Old 05-11-2015, 06:39 PM   #2
I would begin the diagnosis process by doing a fuel pressure test.
Old 05-11-2015, 06:43 PM   #3
robin_gt's Avatar
i'll get on that tomorrow,
is it possible that i kinda just flooded the engine with fuel because when i started it i had the gas pedal half way down and maybe the tps just started dumping gas into the engine. (dont ask why i held the throttle lol) this late starting has happened a couple times but only when the car is hot (maybe starter gets heatsoaking?)
anyways at how many psi should the fuel pressure be?
Old 05-11-2015, 07:04 PM   #4
30-55 psi.
And the system should hold pressure for five minutes, and lose no more than 5 psi.
Old 05-11-2015, 08:03 PM   #5
Crank and or cam position sensors could be out. Check for any codes with an OBD2 scanner. Sensor out=car does not know where to fire on initial startup so just starts firing randomly until the motor catches.
Remote start/push to start GT_Man 2011-2014 Mustang GT 9 01-31-2015 11:57 PM
Thought I'd share pics of my successful Push-to-Start/Remote start install! Jordan.Cortina General Mustang Discussion 32 01-30-2015 08:29 AM
Cold start idle issue. FutileTerror9 1979-1995 Mustang GT 3 06-10-2013 07:36 AM
intermittent start up issue Terminator 2005-2010 Mustang GT 11 04-05-2013 08:24 PM
Cold Start/ Idling issue CodyNelson 1996-2004 Mustang GT 11 09-24-2011 10:34 AM
08:06 PM
