lock problem and window replacement question - Mustang Evolution
Old 05-11-2015, 04:55 PM   #1
My key wont turn in my doors key hole! Had nothing at all to try and get the car unlocked so resulted in breaking the door glass.
When I hit the powered lock button it takes 3 presses for the lock to totally go down. why is this happening..............
door glass is broken and will need to be replaced. Do I need any specialty tools to remove the glass. a drill maybe. how is the glass held in.
UserName is offline   Reply With Quote
Old 05-11-2015, 06:52 PM   #2
You are going to regret breaking that glass, instead of paying someone to come out and get into your car for you...
Sometimes, when the lock solenoid wears out, it can make it extremely difficult to unlock the door with the key.
You'll figure out what the problem is when you have it apart to repair the glass.
Old 05-12-2015, 04:35 PM   #3
why
Old 05-12-2015, 04:44 PM   #4
NewMtang's Avatar
It would have been cheaper for a locksmith to unlock your door instead of breaking the glass.
Old 05-12-2015, 05:51 PM   #5
wasn't an option at the time. I know the glass is on a slider that raises and lowers the window. how is the window held on is it a rivet or glued in place. want to find out so I can get a drill if I have to
Old 05-12-2015, 07:32 PM   #6
My 96 had the same issue with the switches acting up. Installed new lock switches and solved the problem. Now I was in the same boat as you. I had to unlock it with my key. Well the door lock was wearing out and acting up. Instead of fixing it I went and paid like $250 bucks to have keyless remote installed. It opens the trunk too so it was worth it for me. Plus I won't wear out the door locks any longer. Sucks about the window can't help you there. Haven't done one myself.
aero86 is offline   Reply With Quote
Old 05-12-2015, 09:42 PM   #7
Yes. You will need a drill to remove two glass mounting rivets.
Old 05-13-2015, 04:04 AM   #8
$250 hope that came with remote start. you can actually buy keyless remotes and program them yourself for our cars. I need to get one
Mustang Keyless Entry Remote Fob (99-14 All) - Free Shipping
Old 05-13-2015, 04:05 AM   #9
figured that. do you know how I am supposed to get the new window to hold in place securely
Old 05-13-2015, 10:55 AM   #10
The installation is the reverse of the removal. You will need a rivet gun to securely rivet the window back into place.
Old 05-13-2015, 04:34 PM   #11
and that is why I asked so now gotta pick up a rivet gun any idea of size
Old 05-13-2015, 05:43 PM   #12
I'm not sure what size that the rivet is. You will probably have to remove the door panel and try to determine which size rivet that you will need, and then get the appropriate sized gun.
Old 05-13-2015, 06:54 PM   #13
If you're talking about pop rivets then you just buy the one gun and it has different size tips for different size rivets. Then all you need to figure out is what size rivets you need.
Old 05-13-2015, 07:13 PM   #14
WJL
The rivets are large IIRC they are like 1/4" Dia. or bigger. I think i used a 1/4" drill bit to drill them out
I have used nuts and bolts but you have to make sure to use lock washers and the length of the bolt is critical so that it don't interfere with anything else inside the door
(goes up & Down with out rubbing)
good luck
WJL is offline   Reply With Quote
Old 05-14-2015, 04:02 AM   #15
good luck
Thank You. Do you remember what size bolt washer and nuts that you used so I can take out the guessing lol would probably be more ideal then buying a rivet gun
Old 05-14-2015, 03:44 PM   #16
WJL
I think i used 1/4" x 3/4" or 1" and now that i think about it i used nylock nuts and not lock washers.
I don't know what your experience is but just in case nylock nut are nuts that have a nylon end on it that keeps it from vibrating off.
you will have to move the window track to get at the rivets to drill them out.
Its really not that difficult, remove the door skin, drill rivets out install new glass bolt up and put the skin back on shouldn't take more than an hour or so
Check youtube someone probably has a video.
Old 05-14-2015, 06:02 PM   #17
So let me get this straight... BOTH your door locks failed at the exact same time and the trunk too? Seeing as there are pull tabs for the folding seats in the trunk...
This isn't suspicious as hell or anything...
Old 05-16-2015, 08:29 AM   #18
I only have a driver side key hole. My passenger side door doesn't.. and as for the trunk.. maybe if there was some small people around I could have thrown one in the trunk to climb thru.
car wont start/lock problem - urgently requires a locksmith Twandalu 2005-2010 Mustang GT 3 02-10-2013 08:58 PM
Door lock cylinder problem Qwik Four Six 1979-1995 Mustang GT 13 01-09-2011 12:02 PM
Wiring harness or lock/window assembly? rachl1999 Pre-2005 V6 Mustang 3 08-04-2009 01:36 AM
Power window and lock problem need help blzfan1963 Pre-2005 V6 Mustang 3 08-08-2008 06:35 AM
Ignition Lock problem BlueDonkey Pre-2005 V6 Mustang 11 12-31-2004 05:43 PM
09:17 PM
